Error: Connection between Access DB and a SHP file ...
Thomas Grosser
grosser at kom21.de
Tue May 30 11:38:04 EDT 2006
Hi to all,
I´m trying to connect a database (MS Access) to a SHP file and get the following error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.GetDefaultableFeatureClass(List`1 classes)
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.ValidateFeatureSources(FeatureClass& primaryClass, String& resourceId, FeatureClass& joinClass)
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.CreateNewExtension(String resourceId)
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.toolBar_ButtonClick(Object sender, ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.OnButtonClick(ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.WmReflectCommand(Message& m)
at System.Windows.Forms.ToolBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Studio
Assembly Version: 1.0.0.16802
Win32 Version: 1.0.0.16802
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Studio.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.MapGuide.Studio.Locale
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Locale.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd/msvcm80.dll
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.UI.DLL
Autodesk.Gis.DwfToolkit
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.Gis.DwfToolkit.DLL
Autodesk.MapGuide.Studio.Feature
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Feature.DLL
Autodesk.MapGuide.Studio.FdoLoader
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.FdoLoader.DLL
Autodesk.MapGuide.Forms
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Forms.DLL
Autodesk.MapGuide.Studio.Site.UI
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Site.UI.DLL
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Site.DLL
Autodesk.MapGuide.Studio.MdfModel
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.MdfModel.DLL
Autodesk.MapGuide.Studio.ImageEngine
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.ImageEngine.DLL
Autodesk.MapGuide.Studio.Load
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Load.DLL
Autodesk.MapGuide.Studio.Load.Serializer
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Load.Serializer.DLL
System.Web
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
_owhkl2m
ss0urkvh
k1qss87w
9ahucjjy
Autodesk.Gis.CoordinateSystems
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.Gis.CoordinateSystems.DLL
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Microsoft.mshtml.DLL
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.Fdo.DLL
c2h3rqwq
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Autodesk.MapGuide.Studio.StylePreview
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Autodesk.MapGuide.Studio.StylePreview.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
kbnxf3qi
k6avsajb
adqqallr
qsizlgo3
tin5ty0e
Ping
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/Ping.DLL
k-qhjrxq
ICSharpCode.SharpZipLib
Assembly Version: 0.81.0.1407
Win32 Version: 0.81.0.1407
CodeBase: file:///C:/Programme/Autodesk/MapGuideStudioPreview/ICSharpCode.SharpZipLib.DLL
yse-pkzo
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
So my question is: What must i do to connect to an Access-DB via ODBC and than what to do to connect htis DB to an SHP file ? Can somone help me here ?
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
More information about the Mapguide-users
