[mapguide-users] error running dotnetviewersample
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Nov 2 02:00:08 EST 2006
The real problem is that the samples weren't actually updated to reflect
the API change. We'll get that fixed.
_____
Sent: Thursday, November 02, 2006 4:01 AM
Subject: Re: [mapguide-users] error running dotnetviewersample
thankyou, it works like a charm.
better work with vs2005, the intelesense helps a lot...
Andy Morsell wrote:
Remove any InitializeSockets() and TerminateSockets() you run
across in the .NET examples and it should then work. They were both
removed from the API definition.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
Sent: Wednesday, November 01, 2006 5:15 PM
Subject: [mapguide-users] error running dotnetviewersample
hi,
i'm running mgos v1.0.2 on win2003 and dotnet 2.0.
from the previous post, i've already do all the necessay steps
to run dotnet sample
-load "Sheboygan.mgp"
-extract "dotnetviewersample", make it run as aplication
-copy all the "bin" folder from "mapviewernet" to
-copy the "webconfig".ini file on the "www" root to
"dotnetviwersample"
but, there seems an error occured, the message error like this,
and it happens bot on win2003+iis6 and win2000+iis5
Compiler Error Message: CS0117: 'MapGuideApi' does not contain a
definition for 'InitializeSockets'
Source Error:
Line 31: try
Line 32: {
Line 33: MapGuideApi.InitializeSockets();
Line 34: InitializeWebTier();
Line 35:
Source File: c:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\ajax
viewersample.aspx Line: 33
how can i fix it?
thankyou
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061102/92c08f34/attachment.html
More information about the Mapguide-users
