[mapguide-users] RE: WMS Data Source?
Andy Morsell amorsell at spatialgis.com
Fri Nov 3 20:44:17 EST 2006
I actually searched Project Tracker before posting.  I made the mistake of
searching for "digitalearth".
Thanks for the info Jason.
Andy
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, November 03, 2006 5:34 PM
Subject: RE: [mapguide-users] RE: WMS Data Source?
This is a known issue:
 <https://mapguide.osgeo.org/servlets/Scarab?id=MG434>
It looks like you may be able to fix it by grabbing the three fixed files
from SVN:
<https://mapguide.osgeo.org/source/browse/mapguide/branches/1.0.x/MgDev/Serv
er/src/Wms/>
https://mapguide.osgeo.org/source/browse/mapguide/branches/1.0.x/MgDev/Serve
r/src/Wms/
or just updating the AWD templates on your site to hit OGC instead of
digitalearth (weird choice):
 <http://schemas.opengis.net/wms/1.0.0/capabilities_1_0_0.dtd>
 <http://schemas.opengis.net/wms/1.1.0/capabilities_1_1_0.dtd>
 <http://schemas.opengis.net/wms/1.1.1/capabilities_1_1_1.dtd>
respectively, for the three templates.
I recall something similar with LiteView in MapGuide 6.x, and I think I had
to repoint to a local DTD.  Bit fuzzy on that though; I gave up on LiteView
pretty quickly.
Jason
  _____
Sent: Fri 2006-11-03 5:12 PM
There is an OSGeo FDO WMS data provider for this purpose
(https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=100
<https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=100&expand
> &expand
Folder=100&folderID=0).  However, I just tried working with it and there
appears to be a problem today.  If you try to use it to define a data
connection, and then enter a WMS server name and press the Test Connection
button, you will get an error
"An exception occurred in FDO component.
XML Document parse error at line 8 column 3: An exception occurred!
Type:NetAccessorException, Message:The host/address 'www.digitalearth.gov'
could not be resolved "
It appears that the FDO provider is looking up a DTD at digitalearth.gov and
their web site is currently down (at least on my end).
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061103/79017cc6/winmail.bin
More information about the Mapguide-users mailing list
