Fdo2Fdo
Haris Kurtagic haris at sl-king.com
Mon Nov 6 12:58:56 EST 2006
Fdo2Fdo is a tool I am using to work with, learn and test FDO and
perhaps it can help to someone else also.
It is a FDO client application for copying FDO Data Sources and manage
FDO Data Sources with additional tools to work with Oracle.
It has two parts: standard library as fdo client and windows
application.
Some features:
1. Copy to/from SHP, SDF, Oracle ( didn't tested others but could work)
http://www.sl-king.com/fdo2fdo/screenshots_copy.html
2. Copy to Oracle and it will setup all stuff so you can view it
immediately in MapGuide (sdo metadata, spatial index, layer type,
primary key)
3. Fdo Toolbox: useful utilities for testing fdo providers and schemas
http://www.sl-king.com/fdo2fdo/screenshots_fdo.html
4. Oracle toolbox - manage sdo metadata, spatial index, primary keys
http://www.sl-king.com/fdo2fdo/screenshots_ora.html
5. API c, .net  http://www.sl-king.com/fdo2fdo/fdo2fdo_api.html
You can get it here:  www.sl-king.com/fdo2fdo
It is a self contained application.
It is 38 MB .zip file which you unzip and ready to go. It contains:
complete fdo, shp,sdf,king.oracle provider, oracle instant client and
needed microsoft redistributables.
I tested it around sdf,shp and oracle but it is general fdo client so it
could work with others also, if not let me know and I will try to fix
it.
If some of this, is material for open source I am happy to make it so.
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061106/a02e2a07/attachment.html
More information about the Mapguide-users mailing list
