[mapguide-users] Permissions problem...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Nov 7 12:14:39 EST 2006
Ah...sorry. I should have posted the error that it gives me.....When I
try to use the DWF Viewer, this is what I get:
Permission denied to resource: Library://test/
Permission denied to resource: Library://test/ Exception occurred in
method MgResourceHeaderManager.CheckPermission at line 2495 in file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceHeaderManager.cpp
Andrew
Walt Welton-Lair wrote:
> So DWF Viewer doesn't prompt for credentials. Do you get back any
> data or does it just sit there?
> Ultimately DWF Viewer simply makes a Mapping Service GetMap HTTP
> request via WinINet. It prompts for credentials when it gets a 401
> response to that initial request, and then resubmits the GetMap
> request. If it just sits there that means it didn't get a 401
> response and it thinks it's done.
> Walt
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Tuesday, November 07, 2006 4:53 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Permissions problem...
> I've got a project that I want to password protect....I've given a
> specific MapGuide User read permissions to my library (removed
> 'Everyone', and added 'Administrator' as read/write as well). What's
> happening now is that the DWF viewer isn't asking me to log in. If I
> change my URL to use the AJAX viewer, it works fine (asks me to log
> in, and then works as it should). So, for example:
> http://host/mapguide/mapviewerdwf/?WEBLAYOUT=..... ----This does NOT
> work
> http://host/mapguide/mapviewerajax/?WEBLAYOUT=..... ----This DOES work
> This happens on any PC that I've tested it on. Am I missing something
> here, or is this a bug? I'm using v1.0.2.17861 (the latest release).
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
