[mapguide-users] RE: RE: RE: mark symbol action
Andy Morsell
amorsell at spatialgis.com
Wed Nov 8 01:32:07 EST 2006
Hyperlinks wouldn't work in labels since there is no user interaction with
labels, they are for display purposes only. Hyperlinks do work in tooltips,
which in my opinion, is where that sort of functionality should lie.
Andy
-----Original Message-----
Sent: Tuesday, November 07, 2006 10:03 PM
Subject: [mapguide-users] RE: RE: RE: mark symbol action
I got another question, what about in inserting hyperlinks " </ " function
into the label?
I have tried it out but it gave me error message...
I hope you can help me out
Regards,
Kencana
Andy Morsell wrote:
> Line breaks don't work in the AJAX viewer but do with the DWF viewer.
> This
> is as known bug and has been logged in Project Tracker.
> Andy
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Tuesday, November 07, 2006 9:19 PM
> Subject: [mapguide-users] RE: RE: mark symbol action
> Hi,
> I want to ask something..in the label..is that possible to put line
> break?coz I have try to use \n,<br> it doesn't work at all..instead of
> breaking the line it print out the text...
> the following is the coding
> <Label>
> <Unit>Points</Unit>
> <SizeContext>DeviceUnits</SizeContext>
> <SizeX>0.3</SizeX>
> <SizeY>10</SizeY>
> <Text>concat('Address:', concat('<br/>',Address))</Text>
> <FontName>Arial</FontName>
> <ForegroundColor>FF000000</ForegroundColor>
> <BackgroundColor>FFFFFFFF</BackgroundColor>
> <BackgroundStyle>Transparent</BackgroundStyle>
> <HorizontalAlignment>'Center'</HorizontalAlignment>
> <VerticalAlignment>'Baseline'</VerticalAlignment>
> </Label>
> I hope you can help me out from this problem...Thank you
> Regards,
> Kencana
> Farah-2 wrote:
>> Hi,
>> If you are creating the marker layer as per the developer guide
>> method, you should be referring to a xml file while creating the
>> layer right? In that file , make the necessary changes. I am
>> attaching some sample code.
>> Do you mean , is it possible to have links to other pages in the tooltip?
>> I
>> am not sure about that. I havent tried it out.Will let you know if I
>> find
>> out..:-)
>> You can load images into the tooltip though.
>> regards
>> farah
>> Sent: Tuesday, November 07, 2006 5:24 PM
>> Subject: [mapguide-users] RE: mark symbol action
>> Hi,
>> Thanx for the reply, but can you explain more in detail..
>> you mean i should edit the LayerDefinition-1.0.0.xsd file is it?
>> i create the mark symbol by following developer guide method.
>> is that possible to create a tooltip where another web pages is being
>> loaded into the tooltip.
>> just like google map.when you search one particular places it will
>> show a tooltip where contains the respective place information, as
>> well as some other map features such as "What's near by", "how to get
>> here", etc.
>> I am looking forward for the reply, and thank you for the guidance
>> Regards,
>> Kencana
>> Farah-2 wrote:
>>> Hi,
>>> You need to set the url in the layer.xml file. Say for example:
>>> <Url>'http://www.yahoo.com'</Url>
>>> Regards
>>> Farah
>>> Sent: Monday, November 06, 2006 2:32 PM
>>> Subject: [mapguide-users] mark symbol action
>>> hi all,
>>> is that possible to embed an action to a mark symbol like invoke url
>>> action?
>>> regards,
>>> Kencana
>>> View this message in context:
>>> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7195302
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> - To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7217017
>> <?xml version="1.0" encoding="UTF-8"?> <LayerDefinition
>> version="1.0.0"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
>> <VectorLayerDefinition>
>> <ResourceId></ResourceId>
>> <FeatureName>ParcelMarker</FeatureName>
>> <FeatureNameType>FeatureClass</FeatureNameType>
>> <PropertyMapping>
>> <Name>NGO_NAME</Name>
>> <Value>1.Name:</Value>
>> </PropertyMapping>
>> <PropertyMapping>
>> <Name>NGO_ADDRESS</Name>
>> <Value>2.Full Address:</Value>
>> </PropertyMapping>
>> <PropertyMapping>
>> <Name>ORG_TYPE</Name>
>> <Value>3.Type</Value>
>> </PropertyMapping>
>> <Geometry>Location</Geometry>
>> <Url>concat('http://localhost:8008/mapguide/iwp/details.jsp?Id=&
>> a pos;, concat("NGO_ID", concat('&SESSION=',
>> "SESSION_VAL")))</Url>
>> <ToolTip>concat( 'Organisation : ', concat(NGO_NAME, concat( '
>> .\nAddress: ' ,concat( NGO_ADDRESS,concat (' .\nType:
>> ',ORG_TYPE)))))</ToolTip>
>> <VectorScaleRange>
>> <MinScale>100000</MinScale>
>> <MaxScale>35000000</MaxScale>
>> <PointTypeStyle>
>> <DisplayAsText>false</DisplayAsText>
>> <AllowOverpost>false</AllowOverpost>
>> <PointRule>
>> <LegendLabel></LegendLabel>
>> <Label>
>> <Unit>Points</Unit>
>> <SizeX>0.3</SizeX>
>> <SizeY>5</SizeY>
>> <Text></Text>
>> <FontName>Verdana</FontName>
>> <BackgroundStyle>Ghosted</BackgroundStyle>
>> </Label>
>> <PointSymbolization2D>
>> <W2D>
>> <Unit>Millimeters</Unit>
>> <SizeX>7</SizeX>
>> <SizeY>7</SizeY>
>> <W2DSymbol>
> <ResourceId>Library://Arghyam/4.SYMBOLS/BasicSymbols.SymbolLibrary</Re
> source
> Id>
>> <LibraryItemName>PushPin</LibraryItemName>
>> </W2DSymbol>
>> </W2D>
>> </PointSymbolization2D>
>> </PointRule>
>> </PointTypeStyle>
>> </VectorScaleRange>
>> <VectorScaleRange>
>> <MaxScale>100000</MaxScale>
>> <PointTypeStyle>
>> <PointRule>
>> <Label>
>> <Unit>Points</Unit>
>> <SizeX>0.4</SizeX>
>> <SizeY>7</SizeY>
>> <Text>NGO_NAME</Text>
>> <VerticalAlignment>'Top'</VerticalAlignment>
>> </Label>
>> <W2D>
>> <SizeX>7</SizeX>
>> <SizeY>7</SizeY>
>> <W2DSymbol>
> source
> Id>
>> </W2DSymbol>
>> </W2D>
>> </PointRule>
>> </PointTypeStyle>
>> </VectorScaleRange>
>> </VectorLayerDefinition>
>> </LayerDefinition>
> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7232946
http://www.nabble.com/mark-symbol-action-tf2581167.html#a7233223
More information about the Mapguide-users
