[mapguide-users] Permissions problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Nov 8 08:15:01 EST 2006
Too late...I submitted it last night, and don't see a way to edit it.
It's MG446 if you (or anyone else watching this thread) has the means to
edit it....
Andrew
Walt Welton-Lair wrote:
> Thanks.  In the artifact please include the final diagnosis below.
> -----Original Message-----
> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> Sent: Wednesday, November 08, 2006 4:37 AM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] Permissions problem...
> Sounds about right......at least I know I'm not missing something
> obvious. I'll submit an artifact...
> Andrew
>> I tested this a little more, and here's what I found.
>> When opening a web layout using AJAX viewer, the login prompt appears
>> immediately, before *any* server request is even made.  The first
>> server operation then ends up being an authentication request
>> (OpAuthenticate).  After this come the requests for resources - the
>> web layout, etc.  These succeed because we have provided credentials.
>> When opening a web layout using DWF viewer, the behavior is
>> different.  There's a couple of authentication requests that get made
>> using "anonymous" user, but no login prompt has yet been displayed.
>> Then comes a request to get the web layout resource, again using
>> "anonymous".  This fails because user "anonymous" does not have access
>> to the library.  The browser then displays the exception message.
>> At this point the web layout hasn't been loaded and DWF Viewer hasn't
>> even entered into the picture.  So this is a MapGuide web tier
> issue...
>> Walt
>> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> *Sent:* Tuesday, November 07, 2006 6:29 PM
>> *To:* users at mapguide.osgeo.org
>> *Subject:* Re: [mapguide-users] Permissions problem...
>> Ya, that's sort of what I figured was happening....that it's not
>> asking me to log in, because it doesn't have permission to ask...which
>> is a bit silly. If that's the case, then it's a fairly annoying
> bug....
>> Andrew
>>> So it's a question of order.  Should MapGuide first authenticate
>>> before it tries to access the resource (and find out that you don't
>>> have permission)?  It looks like it does it the other way - it checks
>>> whether you have permission before authenticating.  I don't know the
>>> right answer.
>>> I do know that the DWF Viewer code which handles the HTTP request
>>> knows nothing about MapGuide and doesn't know what to do with the
>>> permission denied response.
>>> Walt
>>> *Sent:* Tuesday, November 07, 2006 6:15 PM
>>> Ah...sorry. I should have posted the error that it gives me.....When
>>> I try to use the DWF Viewer, this is what I get:
>>> Permission denied to resource: Library://test/
>>> Permission denied to resource: Library://test/ Exception occurred in
>>> method MgResourceHeaderManager.CheckPermission at line 2495 in file
> c:\build_tux_area\mgdev_opensource\server\src\services\resource\Resource
> HeaderManager.cpp
>>> Andrew
>>>> So DWF Viewer doesn't prompt for credentials.  Do you get back any
>>>> data or does it just sit there?
>>>> Ultimately DWF Viewer simply makes a Mapping Service GetMap HTTP
>>>> request via WinINet.  It prompts for credentials when it gets a 401
>>>> response to that initial request, and then resubmits the GetMap
>>>> request.  If it just sits there that means it didn't get a 401
>>>> response and it thinks it's done.
>>>> Walt
>>>> *Sent:* Tuesday, November 07, 2006 4:53 PM
>>>> *Subject:* [mapguide-users] Permissions problem...
>>>> I've got a project that I want to password protect....I've given a
>>>> specific MapGuide User read permissions to my library (removed
>>>> 'Everyone', and added 'Administrator' as read/write as well). What's
>>>> happening now is that the DWF viewer isn't asking me to log in. If I
>>>> change my URL to use the AJAX viewer, it works fine (asks me to log
>>>> in, and then works as it should). So, for example:
>>>> http://host/mapguide/mapviewerdwf/?WEBLAYOUT=.....   ----This does
>>>> NOT work
>>>> http://host/mapguide/mapviewerajax/?WEBLAYOUT=.....   ----This DOES
> work
>>>> This happens on any PC that I've tested it on. Am I missing
>>>> something here, or is this a bug? I'm using v1.0.2.17861 (the latest
>>>> release).
>>>> Andrew
>>>> 	*Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>> 	*Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
>> 	*Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
