[mapguide-users] A question regarding MGE Studio and DWF
Chris White chris.white at keytraffic.com
Wed Nov 8 08:17:42 EST 2006
Gary,
It is probably worth you comparing the settings for the mapviewerajax
and mapviewerdwf directories, as Ajax works fine I would have thought it
was something to do with the way you have set it up. Full details can be
found in the Installing and Configuring on Windows document.
Cheers,
Chris
-----Original Message-----
From: Gary Morin [mailto:gary.morin at keygis.co.uk]
Sent: 08 November 2006 13:06
Subject: RE: [mapguide-users] A question regarding MGE Studio and DWF
Bump
Any suggestions from anyone will be much appricated
Thanks
> Hi
> Sorry for the delay in given feed back, the challenge dialog box is
> definitely Mapguide.
> Pressing preview in AJAX the challenge dialog box is display you enter
you
> details and it works, for DWF it just keeps showing the challenge
dialog
> box.
> If I press cancel I get:
> Failed to open URL: status code 401 Unauthorised
> Any help will be much appreciated.
> Cheers
> Gary
> > From: Dave Wilson [mailto:dave.wilson at autodesk.com]
> > Sent: 03 November 2006 23:09
DWF
> > Within IIS,
> > check the Directory Security tab. Edit the Anonymous user settings
and
> > ensure Integrated Windows Authentication is disabled. This may be
> > causing some grief. The credentials popup you get should be for MG
> > Enterprise, not your machine login.
> > Regards,
> > Dave
> > Sent: Friday, November 03, 2006 11:20 AM
> > Subject: [mapguide-users] A question regarding MGE Studio and DWF
> > Hi
> > I'm just starting to use MG Enterprise, I had major problem on old
> > machine and it now working(ish)on new PC.
> > I have a question regarding studio security.
> > I'm using MGE on local machine XP pro with IIS and ASP.NET
> > When I view a preview using AJAX I prompted to enter user and
password,
> > which I do with standard values, Administrator etc and it works
fine.
> > But when I try with DWF preview it won't accept the credentials, I
just
> > can't get in to view, can someone help me out.
> > Thanks
> > Gary
> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail: users-help at mapguide.osgeo.org
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
More information about the Mapguide-users mailing list
