[mapguide-users] RE: RE: mark symbol action
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Nov 8 10:14:30 EST 2006
It was submitted after 1.0.2.
-----Original Message-----
From: Knight, Gregory [mailto:Gregory.Knight.bra at cityofboston.gov]
Sent: Wednesday, November 08, 2006 3:04 PM
Subject: RE: [mapguide-users] RE: RE: mark symbol action
This is great news! Does 'in the vault' mean that its not in 1.0.2 -
and that it will be in the next compiled/installer?
Thanks,
Greg
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Wednesday, November 08, 2006 5:53 AM
FYI, AJAX viewer support for multi-line labels has since been fixed in
the vault...
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, November 08, 2006 6:23 AM
Line breaks don't work in the AJAX viewer but do with the DWF viewer.
This
is as known bug and has been logged in Project Tracker.
Andy
Sent: Tuesday, November 07, 2006 9:19 PM
Subject: [mapguide-users] RE: RE: mark symbol action
I want to ask something..in the label..is that possible to put line
break?coz I have try to use \n,<br> it doesn't work at all..instead of
breaking the line it print out the text...
the following is the coding
<Label>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
<SizeX>0.3</SizeX>
<SizeY>10</SizeY>
<Text>concat('Address:', concat('<br/>',Address))</Text>
<FontName>Arial</FontName>
<ForegroundColor>FF000000</ForegroundColor>
<BackgroundColor>FFFFFFFF</BackgroundColor>
<BackgroundStyle>Transparent</BackgroundStyle>
<HorizontalAlignment>'Center'</HorizontalAlignment>
<VerticalAlignment>'Baseline'</VerticalAlignment>
</Label>
I hope you can help me out from this problem...Thank you
Regards,
Kencana
Farah-2 wrote:
> Hi,
> If you are creating the marker layer as per the developer guide
> method, you should be referring to a xml file while creating the layer
> right? In that file , make the necessary changes. I am attaching some
> sample code.
> Do you mean , is it possible to have links to other pages in the
tooltip?
> I
> am not sure about that. I havent tried it out.Will let you know if I
> find
> out..:-)
> You can load images into the tooltip though.
> regards
> farah
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Tuesday, November 07, 2006 5:24 PM
> Subject: [mapguide-users] RE: mark symbol action
> Hi,
> Thanx for the reply, but can you explain more in detail..
> you mean i should edit the LayerDefinition-1.0.0.xsd file is it?
> i create the mark symbol by following developer guide method.
> is that possible to create a tooltip where another web pages is being
> loaded into the tooltip.
> just like google map.when you search one particular places it will
> show a tooltip where contains the respective place information, as
> well as some other map features such as "What's near by", "how to get
> here", etc.
> I am looking forward for the reply, and thank you for the guidance
> Regards,
> Kencana
> Farah-2 wrote:
>> Hi,
>> You need to set the url in the layer.xml file. Say for example:
>> <Url>'http://www.yahoo.com'</Url>
>> Regards
>> Farah
>> Sent: Monday, November 06, 2006 2:32 PM
>> Subject: [mapguide-users] mark symbol action
>> hi all,
>> is that possible to embed an action to a mark symbol like invoke url
>> action?
>> regards,
>> Kencana
>> View this message in context:
>> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7195302
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7217017
> <?xml version="1.0" encoding="UTF-8"?> <LayerDefinition
> version="1.0.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
> <VectorLayerDefinition>
> <ResourceId></ResourceId>
> <FeatureName>ParcelMarker</FeatureName>
> <FeatureNameType>FeatureClass</FeatureNameType>
> <PropertyMapping>
> <Name>NGO_NAME</Name>
> <Value>1.Name:</Value>
> </PropertyMapping>
> <PropertyMapping>
> <Name>NGO_ADDRESS</Name>
> <Value>2.Full Address:</Value>
> </PropertyMapping>
> <PropertyMapping>
> <Name>ORG_TYPE</Name>
> <Value>3.Type</Value>
> </PropertyMapping>
> <Geometry>Location</Geometry>
> <Url>concat('http://localhost:8008/mapguide/iwp/details.jsp?Id=&a
> pos;, concat("NGO_ID", concat('&SESSION=',
> "SESSION_VAL")))</Url>
> <ToolTip>concat( 'Organisation : ', concat(NGO_NAME, concat( '
> .\nAddress: ' ,concat( NGO_ADDRESS,concat (' .\nType:
> ',ORG_TYPE)))))</ToolTip>
> <VectorScaleRange>
> <MinScale>100000</MinScale>
> <MaxScale>35000000</MaxScale>
> <PointTypeStyle>
> <DisplayAsText>false</DisplayAsText>
> <AllowOverpost>false</AllowOverpost>
> <PointRule>
> <LegendLabel></LegendLabel>
> <Label>
> <Unit>Points</Unit>
> <SizeX>0.3</SizeX>
> <SizeY>5</SizeY>
> <Text></Text>
> <FontName>Verdana</FontName>
> <BackgroundStyle>Ghosted</BackgroundStyle>
> </Label>
> <PointSymbolization2D>
> <W2D>
> <Unit>Millimeters</Unit>
> <SizeX>7</SizeX>
> <SizeY>7</SizeY>
> <W2DSymbol>
<ResourceId>Library://Arghyam/4.SYMBOLS/BasicSymbols.SymbolLibrary</Reso
urce
Id>
> <LibraryItemName>PushPin</LibraryItemName>
> </W2DSymbol>
> </W2D>
> </PointSymbolization2D>
> </PointRule>
> </PointTypeStyle>
> </VectorScaleRange>
> <VectorScaleRange>
> <MaxScale>100000</MaxScale>
> <PointTypeStyle>
> <PointRule>
> <Label>
> <Unit>Points</Unit>
> <SizeX>0.4</SizeX>
> <SizeY>7</SizeY>
> <Text>NGO_NAME</Text>
<VerticalAlignment>'Top'</VerticalAlignment>
> </Label>
> <W2D>
> <SizeX>7</SizeX>
> <SizeY>7</SizeY>
> <W2DSymbol>
urce
Id>
> </W2DSymbol>
> </W2D>
> </PointRule>
> </PointTypeStyle>
> </VectorScaleRange>
> </VectorLayerDefinition>
> </LayerDefinition>
http://www.nabble.com/mark-symbol-action-tf2581167.html#a7232946
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
More information about the Mapguide-users
