MySQL FDO and Fedora 4
Andy Morsell
amorsell at spatialgis.com
Wed Nov 8 21:10:55 EST 2006
I am trying to get all things MapGuide Open up and running on a Linux Fedora
4 install. One of the requirements is to use MySQL. When doing the
install, I am a little baffled about the FDO build requirements so I'm
hoping somebody can shed some light. The MapGuide Open Source "Building and
Configuring on Linux" document says that FDO 3.0 must be built on the server
before building MapGuide Server and the Web Extensions.
So, this leads me to the FDO project where the current Linux FDO tarball
only contains the SDF and SHP providers. The version of FDO is 3.1. Since
I need the MySQL provider, I find that I need to checkout the source from
SVN, but SVN appears to only contain FDO 3.2 version source files. Also,
the FDO build PDF file indicates that there should be tar files for the
other providers, but the referenced URL only has the above mentioned 3.1 and
3.0 tars.
Should I build FDO from version 3.2 or not? Doesn't MGOS 1.0.2 use FDO 3.1
or is that just what comes in the bundled Windows install? Will FDO 3.2 work
fine with MGOS if it's manually built?
Any other hints on the steps to take would be greatly appreciated.
Thanks very much.
Andy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061108/72e7caef/attachment.html
More information about the Mapguide-users
