[mapguide-users] MySQL FDO and Fedora 4
    Tom Fukushima
    tom.fukushima at autodesk.com
    Fri Nov 10 11:07:12 EST 2006
Hi Andy,
This is an error in the build script.  I have updated the wiki page with instructions on how to get around the error.  Also, when I tried the build_oem.sh command again today, I found that cppunit was not building anymore; I've also added instructions to fix that.
I'm compiling the latest source now.
Hopefully that's it
Tom
Here is what I added to the wiki page to address this:
There is a error that will occur the first time this is run. You will need to fix the Svc_Conf_l.cpp file using the following commands:
pushd Oem/ACE/ACE_wrappers/ace
rm Svc_Conf_l.cpp
svn update
popd
./build_oem.sh
Also if you get an error building CppUnit. Try the following:
pushd Oem/CppUnit-1.9.14
rm aclocal.m4
popd
./build_oem.sh
	-----Original Message-----
	From: Andy Morsell [mailto:amorsell at spatialgis.com]
	Sent: Fri 2006/11/10 0:26
	Cc:
	Subject: RE: [mapguide-users] MySQL FDO and Fedora 4
	Hi Tom,
	I ran through the process today and tonight and ran into a problem when running the mapguide build_oem.sh script.  I get the below errors related to ACE.  I did go through the process of installing GCC 4.0.2 and that is what both GCC --version and G++ --version shows.  Any ideas would be appreciated at this point.  Thank you.
	[root at localhost <mailto:root at localhost>  mapguide]# ./build_oem.sh MapGuide Open Source build script for OEM components OEM Build Initialization ............................ Oem Libraries will be installed at: /usr/local/mapguideopensource /src/mgos/mapguide/Oem /src/mgos/mapguide ace: Initialization...........................
	ace: Configure /Build...........................
	/src/mgos/mapguide/Oem/ACE/ACE_wrappers /src/mgos/mapguide/Oem /src/mgos/mapguide
	/src/mgos/mapguide/Oem/ACE/ACE_wrappers/ace /src/mgos/mapguide/Oem/ACE/ACE_wrappers /src/mgos/mapguide/Oem /src/mgos/mapguide
	make[1]: Entering directory `/src/mgos/mapguide/Oem/ACE/ACE_wrappers/ace'
	 Makefile: /src/mgos/mapguide/Oem/ACE/ACE_wrappers/ace/Makefile.ace
	 g++ -W -Wall -Wpointer-arith -pipe -O3 -g -fno-implicit-templates   -D_REENTRANT -DACE_HAS_AIO_CALLS -D_GNU_SOURCE -DACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION   -I/src/mgos/mapguide/Oem/ACE/ACE_wrappers -DACE_HAS_EXCEPTIONS -D__ACE_INLINE__ -DACE_BUILD_DLL -DACE_OS_BUILD_DLL  -c -fPIC -o .shobj/Svc_Conf_l.o Svc_Conf_l.cpp
	Svc_Conf_l.cpp:45:1: error: unterminated #if Svc_Conf_l.cpp:207: warning: ‘ace_yy_current_buffer’ defined but not used
	Svc_Conf_l.cpp:217: warning: ‘ace_yy_hold_char’ defined but not used
	Svc_Conf_l.cpp:219: warning: ‘ace_yy_n_chars’ defined but not used
	Svc_Conf_l.cpp:225: warning: ‘ace_yy_c_buf_p’ defined but not used
	Svc_Conf_l.cpp:226: warning: ‘ace_yy_init’ defined but not used
	Svc_Conf_l.cpp:227: warning: ‘ace_yy_start’ defined but not used
	Svc_Conf_l.cpp:232: warning: ‘ace_yy_did_buffer_switch_on_eof’ defined but not used
	Svc_Conf_l.cpp:248: warning: ‘void* ace_yy_flex_alloc(ace_yy_size_t)’ declared ‘static’ but never defined
	Svc_Conf_l.cpp:249: warning: ‘void* ace_yy_flex_realloc(void*, ace_yy_size_t)’ declared ‘static’ but never defined
	Svc_Conf_l.cpp:250: warning: ‘void ace_yy_flex_free(void*)’ declared ‘static’ but never definedmake[1]: *** [.shobj/Svc_Conf_l.o] Error 1
	make[1]: Leaving directory `/src/mgos/mapguide/Oem/ACE/ACE_wrappers/ace'
	make: *** [all] Error 2
	ACE 5.4: Error build failed (0).................
	[root at localhost mapguide]#
	Andy
  _____
	From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
	Sent: Thursday, November 09, 2006 9:24 AM
	Hi Andy,
	There is no source provided for the 3.1 MySQL provider.  It is part of the 3.2 source (as you have noticed). If you want to build from the latest source, I put some step by step instructions for building the latest MapGuide source on Fedora Core 4 at http://wiki.osgeo.org/index.php/Building_MapGuide_on_Fedora_Core_4 <http://wiki.osgeo.org/index.php/Building_MapGuide_on_Fedora_Core_4> . I went through this process about a month ago, so I think the steps should be good, but I probably missed something. Of course, feel free to correct, update, reformat, etc. any information on that page.
	Tom
  _____
	Sent: Wednesday, November 08, 2006 7:11 PM
	Subject: [mapguide-users] MySQL FDO and Fedora 4
	I am trying to get all things MapGuide Open up and running on a Linux Fedora 4 install.  One of the requirements is to use MySQL.  When doing the install, I am a little baffled about the FDO build requirements so I'm hoping somebody can shed some light.  The MapGuide Open Source "Building and Configuring on Linux" document says that FDO 3.0 must be built on the server before building MapGuide Server and the Web Extensions.
	So, this leads me to the FDO project where the current Linux FDO tarball only contains the SDF and SHP providers.  The version of FDO is 3.1.  Since I need the MySQL provider, I find that I need to checkout the source from SVN, but SVN appears to only contain FDO 3.2 version source files.  Also, the FDO build PDF file indicates that there should be tar files for the other providers, but the referenced URL only has the above mentioned 3.1 and 3.0 tars.
	Should I build FDO from version 3.2 or not?  Doesn't MGOS 1.0.2 use FDO 3.1 or is that just what comes in the bundled Windows install? Will FDO 3.2 work fine with MGOS if it's manually built?
	Any other hints on the steps to take would be greatly appreciated.
	Thanks very much.
	Andy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061110/4dbd04c6/attachment.html
More information about the Mapguide-users
