[mapguide-users] checking wms connections
joanne cook
j.cook at oxfordarch.co.uk
Tue Nov 14 03:57:53 EST 2006
Hi Andy,
Thanks for the quick response. The GetCapabilities request gives me what seems to be a perfectly valid xml file (attached, hopefully). At first I had a lot of trouble with the attached wmsclient.html, but then I realised that on it's way over the email it had been butchered by network antivirus scanners. All the form code had been prefixed defang_html, and the javascript had been commented out. Once I'd resolved that, then I got a valid GetMap request from both the Sheboygan and my own data. Thanks!
Now I just have to figure out how to get it working with OpenLayers- which still doesn't seem to work.
All the best
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Mon 13/11/2006 16:29
Subject: RE: [mapguide-users] checking wms connections
What do you get from this?
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?REQUEST=GetCapabilitie
s&SERVICE=WMS&FORMAT=text/xml
Also attached is an email from Thomas Tuerke from July that has handy little
wms client test page in it. I hope it comes through on the email list.
Andy
-----Original Message-----
From: joanne cook [mailto:j.cook at oxfordarch.co.uk]
Sent: Monday, November 13, 2006 7:40 AM
Subject: [mapguide-users] checking wms connections
Hi All,
I am trying to make a wms connection to some layers in my MapGuide
OpenSource 1.0.2 map. I can't connect to my own, and assume there's some
kind of problem with the conversion from a different coordinate system, as
seems to have been discussed at length on this list, so I thought I'd better
try the Sheboygan data first. All I am trying to do is connect to the data
in Firefox 2, using the following URL:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.
1.1&REQUEST=GetMap&LAYERS=Samples/Sheboygan/Layers/Buildings&FORMAT=image/pn
g
This gives me the following message:
An unclassified exception occurred.
An unclassified exception occurred. Exception occurred in method
MgHttpWmsGetMap.Execute at line 204 in file
c:\build_tux_area\mgdev_opensource\web\src\httphandler\HttpWmsGetMap.cpp
If I remove any of the parameters I get an xml document back that tells me I
don't have all the parameters I need. A GetCapabilities request seems to
validate as far as I can tell...
The end result of all of this is that I want to be able to use my MapGuide
Open Source data in OpenLayers, but needless to say that doesn't work at all
at the moment either!
Many thanks
Jo
This message has been scanned for viruses by BlackSpider MailControl -
www.blackspider.com
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: text/xml
Desc: getcapabilities.xml
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061114/4f99e36e/getcapabilities.xml
More information about the Mapguide-users
