[mapguide-users] King.Oracle 0.4.4
Haris Kurtagic haris at sl-king.com
Wed Nov 15 05:41:41 EST 2006
Hi Max,
I think data is displayed  but you need to zoom into area of interest.
King.Oracle provider reads extent of data from spatial index for
non-geodetic SRID. In case of geodetic coordinate system (as in your
case) it will read from SDO_GEOM_METDATA.
I suppose you have -180 180 -90 90 for extents. You can check that using
Fdo2Fdo tool "Oracle Toolbox - SDO Metadata".
You can than use Fdo2Fdo to recalculate extent "Recalculate Extent"
button and write it into SDO_GEOM_METADATA. Then when provider reads
again that schema (you need to restart studio) it will use correct
extent and in preview it will be automatically zoomed in that area.
Also you can create a Map in Studio and manually set extents for that
Map.
Haris
Sent: Wednesday, November 15, 2006 8:27 AM
Subject: [mapguide-users] King.Oracle 0.4.4
        I tried to load the shapefile into the oracle 10gR2 using the
fdo2fdo tool and after sucessfully loading the shapfile ,i tried to
connect the Spatial Table with the Autodesk MapStudio 2007 using the the
King.Oracle 0.4.4.0 provider ,i sucessfully able to connect to the
oracle database and able to get related attributes in the Layer Editior
but unable to view the Layer in the layer preview window,.
Please refer to the attached pdf file for the details and any kind of
help will be highly appreciated.
Max
Haris Kurtagic <haris at sl-king.com> wrote:
	Hi Juan,
	Great, I would like to see the sites you created.
	Haris
	From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
	Sent: Monday, November 13, 2006 5:56 PM
	Subject: RE: [mapguide-users] King.Oracle 0.3.3
	Great...I will get this loaded and tested.
	It's be going really well lately (in terms of performance) and
I'm about ready to release some sites to the Public.  The anti-Microsoft
crowd should be pleased with the AJAX viewer.
	Juan Butler - Senior Programmer/Analyst
	GIS Applications
	Pinellas County Information Systems
	jpbutler at pinellascounty.org
	Please note: All mail sent to and from Pinellas County
Government is subject to the Public Records Law of Florida.
	Sent: Friday, November 10, 2006 9:23 AM
	I have found a issue with provider not closing all statements
(started in version 0.3.2) , so this could lead to increase of memory
usage.
	I fix it in 0.4.4 version of provider.
	It would be great if you can try that and tell me if it is
working for you now.
	Haris
	Sent: Tuesday, October 24, 2006 7:52 PM
	Haris:
	I'm testing this now and it seems that your provider is pulling
up the spatial data much faster.  The only problem that I'm running into
is the server process is eating up memory at a large clip when adding
more layers from Oracle.  It's gotten up to over a GIG.   I've had to
shutdown Mapguide server completely and then restart it.  The memory
usage will go back up as I interact with more Oracle spatial layers.
Not sure if it's more on the Mapguide server side or the provider.
	I just wish I could use this for non Oracle Spatial tables with
coordinate fields.  The ODBC provider will not show tables for me.
	GIS Applications
	Sent: Tuesday, October 24, 2006 7:17 AM
	Subject: [mapguide-users] King.Oracle 0.3.3
	newer version of King.Oracle 0.3.3 provider:
	*	Support for Spatial Views
		It will display views based on spatial tables. Views
needs to be added into sdo_geom_metadata for provider to find them.
	Get it here: www.sl-king.com/fdooracle
	Haris
Sponsored Link
Don't quit your job
<http://www.classesusa.com/clickcount.cfm?id=607556&goto=http%3A%2F%2Fww
w.classesusa.com%2Ffeaturedschools%2Fonlinedegreesmp%2Fform-dyn1.html%3F
splovr%3D607555>  - take classes online and earn your degree in 1 year.
Start Today
splovr%3D607555>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061115/0f18363f/attachment.html
More information about the Mapguide-users mailing list
