[mapguide-users] King.Oracle 0.4.4
Joel Carranza jec at gatekeeper.com
Wed Nov 15 13:48:28 EST 2006
Haris,
One of the problems we still face with the described setup is that, when
using views, we don't really have the options of declaring spatial
indexes to define the geometry type of the layer. I don't know if you
can even create a spatial index on a view, but even if you could, we
might have a large number of views based on the same underlying table.
We don't really want to create a spatial index for each additional view.
Have you given any thought to previous discussions we about a
"back-door" configuration option, which allows us to specify overrides
for primary key and geometry type for the tables in a schema?
BTW, the provider is running great on our dataset. Thanks for the hard
work!
Joel
Haris Kurtagic wrote:
> Hi,
> Here is document which describes how King.Oracle provider uses Oracle
> Spatial.
> It is about configuring Oracle metadata, Oracle views, spatial
> indexes, primary keys and sequences for use with King.Oracle provider.
> http://www.sl-king.com/fdooracle/KingOracleSetup.html
> I hope this is readable and understandable document and sorry for
> probable mistakes in English, any suggestions and corrections are welcome.
> Haris
> *From:* Rahul [mailto:unicorn_admirer at yahoo.com]
> *Sent:* Wednesday, November 15, 2006 8:27 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] King.Oracle 0.4.4
> Hi,
>         I tried to load the shapefile into the oracle 10gR2 using the*
> fdo2fdo* tool and after sucessfully loading the shapfile ,i tried to
> connect the Spatial Table with the Autodesk MapStudio 2007 using the
> the *King.Oracle 0.4.4.0* provider ,i sucessfully able to connect to
> the oracle database and able to get related attributes in the Layer
> Editior but unable to view the Layer in the layer preview window,.
> Please refer to the attached pdf file for the details and any kind of
> help will be highly appreciated.
> Max
> */Haris Kurtagic <haris at sl-king.com>/* wrote:
>     Hi Juan,
>     Great, I would like to see the sites you created.
>     Haris
>     *From:* Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
>     *Sent:* Monday, November 13, 2006 5:56 PM
>     *Subject:* RE: [mapguide-users] King.Oracle 0.3.3
>     Great...I will get this loaded and tested.
>     It's be going really well lately (in terms of performance) and I'm
>     about ready to release some sites to the Public.  The
>     anti-Microsoft crowd should be pleased with the AJAX viewer.
>     Juan Butler - Senior Programmer/Analyst
>     GIS Applications
>     Pinellas County Information Systems
>     jpbutler at pinellascounty.org <mailto:jpbutler at pinellascounty.org>
>     Please note: All mail sent to and from Pinellas County Government
>     is subject to the Public Records Law of Florida.
>     *From:* Haris Kurtagic [mailto:haris at sl-king.com]
>     *Sent:* Friday, November 10, 2006 9:23 AM
>     I have found a issue with provider not closing all statements
>     (started in version 0.3.2) , so this could lead to increase of
>     memory usage.
>     I fix it in 0.4.4 version of provider.
>     It would be great if you can try that and tell me if it is working
>     for you now.
>     Haris
>     *Sent:* Tuesday, October 24, 2006 7:52 PM
>     Haris:
>     I'm testing this now and it seems that your provider is pulling up
>     the spatial data much faster.  The only problem that I'm running
>     into is the server process is eating up memory at a large clip
>     when adding more layers from Oracle.  It's gotten up to over a
>     GIG.   I've had to shutdown Mapguide server completely and then
>     restart it.  The memory usage will go back up as I interact with
>     more Oracle spatial layers.  Not sure if it's more on the Mapguide
>     server side or the provider.
>     I just wish I could use this for non Oracle Spatial tables with
>     coordinate fields.  The ODBC provider will not show tables for me.
>     GIS Applications
>     *Sent:* Tuesday, October 24, 2006 7:17 AM
>     *Subject:* [mapguide-users] King.Oracle 0.3.3
>     Hi,
>     newer version of King.Oracle 0.3.3 provider:
>         * Support for Spatial Views
>           It will display views based on spatial tables. Views needs
>           to be added into sdo_geom_metadata for provider to find them.
>     Get it here: www.sl-king.com/fdooracle
>     <http://www.sl-king.com/fdooracle>
>     Haris
> Sponsored Link
> Don't quit your job
> <http://www.classesusa.com/clickcount.cfm?id=607556&goto=http%3A%2F%2Fwww.classesusa.com%2Ffeaturedschools%2Fonlinedegreesmp%2Fform-dyn1.html%3Fsplovr%3D607555>
> - take classes online and earn your degree in 1 year. Start Today
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061115/0bce9c66/attachment.html
More information about the Mapguide-users mailing list
