[mapguide-users] RE: Studio Enterprise and Web Studio Cannot Connect Randomly
Jason Birch
Jason.Birch at nanaimo.ca
Wed Nov 15 15:41:09 EST 2006
Thanks, I'll give that a try.
Apparently these can be set on a per-service level, under
HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI\.fcgi
And there is an "Environment" setting. Maybe this could be used to
overcome the problem with the PROJ_LIB variable not getting picked up?
http://viewcvs.php.net/viewvc.cgi/fastcgi-isapi/readme.txt?view=markup
Jason
Subject: RE: [mapguide-users] RE: Studio Enterprise and Web Studio
Hi Jason,
Telling isapi_fcgi and mod_fastcgi to spin up two servers might help but
I've had trouble forcing them to spin up agents. mod_fastcgi is
especially obstinate. Even under load it doesn't like to spin up more
than one agent. Here are the appropriate settings:
For IIS:
Increase the registry setting HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI
StartServers REG_DWORD 1
For Apache, modify httpd.conf and increase -minProcesses:
Change
FastCgiConfig -idle-timeout 120 -minProcesses 1 -maxClassProcesses 4
-multiThreshold 100 -singleThreshold 100 -killInterval 600
to
FastCgiConfig -idle-timeout 120 -minProcesses 2 -maxClassProcesses 4
Note: PHP uses a different configuration line and should already be
spinning up 4 processes:
FastCgiServer "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/php/php-cgi.exe" -processes
4 -idle-timeout 120 -
initial-env PHP_FCGI_MAX_REQUESTS=500 -initial-env PHP_FCGI_CHILDREN=1^M
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061115/fd241fbf/attachment.html
More information about the Mapguide-users
