[mapguide-users] Server Error, unable to connect to fastcgi server. [No Viruses detected]
Chris Gountanis
cgountanis at mpower-tech.com
Thu Nov 16 10:32:52 EST 2006
So, I could set php-cgi.exe over isapi_fcgi.dll as the default PHP handler
in IIS Application Mapping under the MapGuide virtual directory and get the
same FastCGI effect?
Chris Gountanis
Programmer/Analyst - Network Administrator
T: 877-269-6971 | T: 920-830-4053 | F: 920-832-0736
MPOWER TECHNOLOGIES
501 S Nicolet Road Appleton, WI 54914
www.mpower-tech.com
Making complex information more accessible.
-----Original Message-----
Sent: Wednesday, November 15, 2006 8:15 PM
Subject: RE: [mapguide-users] Server Error, unable to connect to fastcgi
No, no,
We want more...
Hi Chris, Hi Tom,
MapAgent.exe and php-cgi.exe are both CGI and FastCGI applications.
They can be configured to function as standalone CGI apps or as longer
lifetime FastCGI apps. As part of the performance optimization for MapGuide
we chose to use FastCGI.
When configured as regular CGI apps, process loading and initialization
becomes a significant part of the execution time. For PHP, the entire API
definition of approximately 130 classes and 1400 methods has to be
registered with the PHP runtime. This is lot of memory allocation and
initialization. The Mapagent loads/initializes faster but it still takes
time. Incurring 200+ milliseconds of overhead for a 10 millisecond HTTP
request was very performance restrictive.
Mapagent.exe and php-cgi.exe also connect to MapGuide Server through TCP/IP.
When run as regular CGI's, these processes can exhaust the ephemeral ports
on both Windows and Linux. From what I remember, the default port pool on
Windows is around 3000 ports and they stay in a TIME_WAIT state for 4
minutes after they are closed. A request rate of around 12 requests per
second for 4 minutes is sufficient to completely exhaust the ephemeral ports
on the server. Once this happens, no new TCP/IP connections will be
accepted for any process running on the machine. Under some of our internal
load tests, I could force this condition in about 30 seconds. When run as
FastCGI apps, the Mapagent and php-cgi reuse existing connections to the
server which completely avoids this problem.
Isapi_fcgi.dll is an IIS extension for handling FastCGI applications.
With the default setups, both Mapagent.exe and php-cgi.exe run under this
IIS extension. The Mapagent.fcgi file is just a placeholder. It makes it
easier to configure either a FastCGI or regular CGI Mapagent without having
to change any URLs. For FastCGI, Mapagent.fcgi redirects to isapi_fcgi.dll
which then calls a running mapagent.exe process. For regular cgi
mapagent.fcgi just redirects to mapagent.exe.
It is possible to configure the Mapagent and php-cgi.exe as regular CGI
apps. Initially, MapGuide was configured that way. But there will be a
performance hit and the default settings for TCP/IP may need to be adjusted
to avoid ephemeral port exhaustion.
Thanks (for reading all this),
Trevor
From: Chris Gountanis [mailto:cgountanis at mpower-tech.com]
Sent: Tuesday, November 14, 2006 10:50 AM
With that being said is there a better way to setup the IIS/PHP config in
IIS. I was told be a few people that they had to change the PHP and FCGI
handlers manually after the fact. Why are PHP pages handled with the
isapi_fcgi.dll file and not the php-cgi.exe file? What is the big diff from
using mapagent.fcgi or using MapAgent.exe directly. What is the fcgi file
actually redirecting to?
Chris
From: Tom Chadwin [mailto:tom.chadwin at nnpa.org.uk]
Sent: Tuesday, November 14, 2006 11:37 AM
Subject: [mapguide-users] Server Error, unable to connect to fastcgi server.
Hello all
I get the following error message intermittently in my W2K3/IIS/PHP
application:
A refresh often gets rid of the problem. I can't find anything in the
Windows event logs. Can anyone point me towards finding the cause of this
problem?
Thanks
Tom
Tom Chadwin
ICT & Web Development Officer
Telephone: 01434 611530
Mobile:
Fax: 01434 611677
Email: tom.chadwin at nnpa.org.uk
Web : www.Northumberland-national-park.org.uk
<http://www.Northumberland-national-park.org.uk>
<http://www.northumberland-national-park.org.uk/>
________________________________________________________________________
____
IMPORTANT NOTICE - Disclaimer - November 14, 2006 - REF
Email-200611-00045249.
If you have received this e-mail in error or wish to read our e-mail
disclaimer statement and monitoring policy, please refer to the statement
below or contact the sender.
This communication is from Northumberland National Park Authority (NNPA).The
Authority's head office and principal place of business is Eastburn, South
Park, Hexham, Northumberland, NE46 1BS, United Kingdom.This communication
and any attachments contain information which is confidential and may also
be privileged. It is for the exclusive use of users at mapguide.osgeo.org. If
you are not the intended recipient(s) please note that any form of
disclosure, distribution, copying or use of this communication or the
information in it or in any attachments is strictly prohibited and may be
unlawful. If you have received this communication in error, please return it
with the title "received in error" to "it.security at nnpa.org.uk" then delete
the email and destroy any copies of it.
E-mail communications cannot be guaranteed to be secure or error free, as
information could be intercepted, corrupted, amended, lost, destroyed,
arrive late or incomplete, or contain viruses. We do not accept liability
for any such matters or their consequences. Anyone who communicates with us
by e-mail is taken to accept the risks in doing so.
Any views or opinions presented are solely those of the author and do not
necessarily represent those of NNPA.Contractors or potential contractors are
reminded that a formal Order or Contract is needed for NNPA to be bound by
any offer or acceptance of terms for the supply of goods or services
Although this email and any attachments are believed to be free of any virus
or other defects which might affect any computer or IT system into which
they are received, no responsibility is accepted by the NNPA for any loss or
damage arising in any way from the receipt or use thereof. Computer systems
of this Authority may be monitored and communications carried out on them
recorded, to secure the effective operation of the system and for other
lawful purposes.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Share your latest news with your friends with the Windows Live Spaces
friends module.
http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spa
ces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mk
More information about the Mapguide-users
