[mapguide-users] Saving map to session doesn't persist?
Chris Gountanis
cgountanis at mpower-tech.com
Fri Nov 17 12:18:59 EST 2006
We have seen this on the Java side as well. As soon as you do a map.save the
session drops and errors out. Seems they do a empty selection as well before
the map save but no reasoning behind that as well. I don't see that logic in
your code. Wondering if that is even needed.
For example:
MgMap map = new MgMap();
MgResourceIdentifier resId = new
MgResourceIdentifier(mapDefinition);
String mapName = resId.GetName();
map.Create(resourceSrvc, resId, mapName);
//create an empty selection object and store it in the session
repository
MgSelection sel = new MgSelection(map);
sel.Save(resourceSrvc, mapName);
Chris
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, November 17, 2006 11:08 AM
Subject: [mapguide-users] Saving map to session doesn't persist?
I've attached an example that I think should save a MapDefinition to the
session repository, but a call to MapAgent to render the map comes up with a
MgResourceNotFoundException (I think).
Is there something that says that MapDefinitions need to be modified to be
persisted? Is there a typo in there somewhere?
Jason
More information about the Mapguide-users
