[mapguide-users] WMS Provider on Linux?
Jason Birch Jason.Birch at nanaimo.ca
Fri Nov 17 13:32:16 EST 2006
I don't think that the MapGuide installation instructions that I looked
at told you that you had to run the install option against the
build_thirdparty script as well as the build script.  This messed me up
on Windows anyway.
Jason
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, November 17, 2006 10:27
Subject: [mapguide-users] WMS Provider on Linux?
I recently built FDO 3.2 and MapGuide Open from subversion on Fedora 4.
When I built FDO, I included all of the optional data providers.
Everything seemed to build fine.
But, when I try to create a layer using the WMS Provider, I get the
following error at the server:
An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 201 in
file FdoConnectionManager.cpp
In the fdo-3.2.0 directory, there are a number of libWMS* files and
providers.xml does have an entry for the WMS provider.  I am
experiencing this same problem on two different Fedora 4 boxes.
Thanks.
Andy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061117/bf757c2b/attachment.html
More information about the Mapguide-users mailing list
