[mapguide-users] WMS EPSG
Jason Birch Jason.Birch at nanaimo.ca
Mon Nov 20 16:02:04 EST 2006
I believe that 102190 was the user-defined code that was commonly used for BC Albers before it got its official number (3005).  They should be identical other than the code, so Brad could probably just copy the entry for 3005 and rename it.
Jason
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Mon 2006-11-20 12:58 PM
Subject: RE: [mapguide-users] WMS EPSG
Brad,
You will need to update the Proj.4 "epsg" file with the definition of
EPSG:102190 and it should work. I tried to google this and couldn't find
it so I'm not sure what it looks like in order to test it.
The Proj.4 file "epsg" is located by the path specified in the
environment variable "PROJ_LIB" and you would want to add the 102190
entry to the end of the file, ie: ..\nad\epsg
Thanks,
Bruce
-----Original Message-----
Sent: November 17, 2006 5:03 PM
Subject: [mapguide-users] WMS EPSG
Hi folks: simple question:  we are using BC Albers EPSG 3005 for our
initial
map projection.  Will  we be able to view  a WMS BC Albers map layer
that
uses  EPSG 102190?
thanks
View this message in context:
http://www.nabble.com/WMS-EPSG-tf2657673.html#a7413308
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061120/a1a8175c/attachment.bin
More information about the Mapguide-users mailing list
