SPAM-LOW: RE: [mapguide-users] Site corrupt - MG Server fails to start
Andy Morsell
amorsell at spatialgis.com
Mon Nov 20 20:23:05 EST 2006
My symptoms were rather baffling, hence my reinstall. What happens at
reboot and as Windows is starting, is the mgserver process will consume 100%
of the CPU. I let this run for 5 minutes or more once. While this is
occurring, the services control panel will indicate that the service is in a
"starting" state. At the same time, all of the other Windows services,
startup programs, etc. are trying to start and fighting for the CPU so
everything slows to a crawl. It did not occur to me to run mgserver in
application mode since the service had always worked fine, but I have
definitely mentally noted that.
Andy
-----Original Message-----
Sent: Monday, November 20, 2006 4:12 PM
Subject: SPAM-LOW: RE: [mapguide-users] Site corrupt - MG Server fails to
start
I don't consider andy a novice. yet he reinstalled his server because of...
If it is very rare it is going to get everybody the same way.
>There is no service or application. As I said the need to do this is
very rare and most likely will not be needed.
If you are running the server as an application all you have to do is look
at the command line and once you see the text "Server started."
appear the repositories have been cleaned up.
Bruce
_____
Sent: November 20, 2006 2:47 PM
Subject: RE: [mapguide-users] Site corrupt - MG Server fails to start
Is there a service or application that could be checked to see if the
cleanup is still running or completed?
_____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Monday, November 20, 2006 3:08 PM
The files might not actually be corrupt, but may have not been closed
properly (example: due to power outage). When the server starts it tries to
"clean up" the repositories using the generated log files. Under certain
circumstances this can take longer then the Windows Service Control Manager
allows for a service starting up. The thing to do in this case is to not run
the server as a service and instead run it interactively as an application
to give the server time to cleanup the repository. Once the repository has
been cleaned up you can stop the server application and restart it as a
service. Note: that you should not have to do this under normal operating
conditions.
Bruce
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: November 18, 2006 9:41 PM
Good cautionary tale.
If anyone is not backing up their repositories, they should strongly
consider it. I haven't seen any problems yet, but the repositories are
file-based and are subject to corruption in the case of interrupted writes,
etc.
There is a RepositoryAdmin directory in the Server installation that
contains some utilities for doing this, and instructions. You can find a
copy of the isntructions here:
https://mapguide.osgeo.org/source/browse/*checkout*/mapguide/trunk/MgDev
/Server/RepositoryAdmin/MgOpenSourceRepositoryAdmin.pdf
Hmm. It would be nice if we could leverage an RDBMS data store to store the
repository info. This would kinda break the managed data idea, but it would
eliminate the load balancing problems around session access. I don't really
like storing my data with the site configuration info anyway :)
Jason
_____
Sent: Sat 2006-11-18 12:14 PM
Subject: [mapguide-users] Site corrupt - MG Server fails to start
I have no idea how this happened, but it is rather disconcerting.
Luckily it was only the Site data that was a problem and that my Library
seems to be fine. Otherwise I would be reaching into my backups to restore
from.
_________________________________________________________________
All-in-one security and maintenance for your PC. Get a free 90-day trial!
http://clk.atdmt.com/MSN/go/msnnkwlo0050000002msn/direct/01/?href=http://clk
.atdmt.com/MSN/go/msnnkwlo0050000001msn/direct/01/?href=http://www.windowson
ecare.com/?sc_cid=msn_hotmail
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
