[mapguide-users] RE: getting map image in svg format
Jason Birch Jason.Birch at nanaimo.ca
Tue Nov 21 00:01:14 EST 2006
SVG is a vector format, so you won't have much fun converting from PNG to SVG.
You could conceivably create your own SVG output scripts, the same way that some of us were querying data elements and outputting KML directly.  I don't think it's impossible, but it's a lot of work, you're pretty much on your own, and it would be difficult to integrate into the AJAX viewer.
http://www.nabble.com/MapGuide-OS-with-Google-Earth-t1289107.html#a3429490
Jason
Sent: Mon 2006-11-20 8:26 PM
Subject: [mapguide-users] RE: getting map image in svg format
Hi Traian,
Thanks for the reply, and I want to ask something about the image format
conversion.
is that possible to code the image format conversion from png to svg in php?
any guidelines available for that?
Regards,
Kencana
Traian Stanev wrote:
> MapGuide doesn't have SVG output (yet?). The options for output are
> currently image, DWF, and KML.
> In general it is possible to do, it would require the implementation of
> a Renderer for SVG.
> Traian
> -----Original Message-----
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Monday, November 20, 2006 4:28 AM
> Subject: [mapguide-users] getting map image in svg format
> Hi all,
> is that possible to get the map image in svg format instead of png
> format?
> if yes, how it can be done?
> Thank you
> Regards,
> Kencana
> http://www.nabble.com/getting-map-image-in-svg-format-tf2667842.html#a74
> 39430
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/getting-map-image-in-svg-format-tf2667842.html#a7465646
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061120/edceec78/attachment.bin
More information about the Mapguide-users mailing list
