[mapguide-users] search based on a value in a joined field
Andy Morsell
amorsell at spatialgis.com
Tue Nov 21 11:05:55 EST 2006
No, this is currently not possible. This is one of the most desirable
features I can think of and an artifact has been already been entered into
MGOS project tracker for this.
https://mapguide.osgeo.org/servlets/Scarab?id=MG444
Andy
_____
From: Arq. Luis E. Marin M. [mailto:luismarin at simbiosisgroup.net]
Sent: Tuesday, November 21, 2006 6:41 AM
Subject: [mapguide-users] search based on a value in a joined field
Importance: High
Is it possible to create a search based on a value in a joined field?
I'm getting the following error when I attempt search a joined field:
An exception occurred in FDO component. Invalid identifier name '<Field
Name>'. Exception occurred in method
MgServerGwsGetFeatures.GetMgClassDefinition at line 207 in file
c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures.cpp
Anybody successfully getting search results from a joined field?
Thanks
CEO
Simbiosis Group Inc.
+58-2129432453 CCS
+58-4166050203 CCS
+01-3109283934 USA
*****REGULACIÓN DE USO DEL CORREO ELECTRÓNICO DE Simbiosis Group Inc. HACIA
INTERNET*****
La información contenida en este correo electrónico y cualquier anexo puede
ser de carácter confidencial y es propiedad de Simbiosis Group Inc. Sólo
está permitido su uso, copia, transmisión, recepción o distribución a
personas debidamente autorizadas. Si usted recibió este correo por error por
favor destrúyalo y/o elimine cualquier copia guardada en su sistema y
notifique inmediatamente al remitente o a la dirección de correo electrónica
<mailto:info at simbiosisgroup.net> info at simbiosisgroup.net. Usted no debe
utilizar la información contenida para ningún propósito ni compartirla con
otras personas.
This e-mail, including any attached files, may contain confidential and
privileged information for the sole use of the Simbiosis Group Inc. Any
review, use, distribution, or disclosure by others is strictly prohibited.
If you are not the intended recipient (or authorized to receive information
for the intended recipient), please contact the sender by reply
<mailto:info at simbiosisgroup.net> info at simbiosisgroup.net and delete all
copies of this message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061121/0d831d12/attachment.html
More information about the Mapguide-users
