Server Error, unable to connect to fastcgi server. [No Viruses detected]
Tom Chadwin tom.chadwin at nnpa.org.uk
Thu Nov 23 04:12:57 EST 2006
Hi Trevor
I have now deployed my MGOS installation on two subsequent w2k3 machines,
and in both cases, I have frequently seen the fastcgi error. I have upped
the values of the registry keys below, and in both cases, as on the
development machine I was initially using, this seems to have solved the
problem.
Thanks
Tom
Trevor Wekel wrote:
> Hi Tom,
> Increasing these registry values may help.  I have not debugged the
> fastcgi teardown/startup in detail to see exactly what happens.  As
> such, I cannot make any guarantees.  But this is likely one of the few
> configuration settings which may have an impact.
> If it does help, please let us (the list) know.
> -----Original Message-----
> From: Tom Chadwin [mailto:tom.chadwin at nnpa.org.uk]
> Many thanks for the detailed explanation. Without wishing to sound
> ungrateful, can you help me out with ways to alleviate the symptom? I've
> tried upping the values of the FastCGI registry keys STARTSERVERS and
> INCREMENTSERVERS. Is this likely to help?
> I get the following error message intermittently in my W2K3/IIS/PHP
> application:
> A refresh often gets rid of the problem. I can't find anything in the
> Windows event logs. Can anyone point me towards finding the cause of
> this problem?
View this message in context: http://www.nabble.com/Server-Error%2C-unable-to-connect-to-fastcgi-server.--No-Viruses-detected--tf2631043.html#a7500851
More information about the Mapguide-users mailing list
