[mapguide-users] MapGuide Studio and DXF / DWG problems....
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Nov 24 12:22:43 EST 2006
I'm not about to try uninstalling my CAD apps here to make Studio work,
so I haven't done that....but other than that, ditto for me. I see the
load sequence and that seems to work....dete.exe starts running and
everything. But then you instantly get the cas error when you try to
load the resource.
Interestingly enough, today it's totally crashing my studio when I try
to load a dxf....that's a first for me. I pick my DXF and it
crashes...every time. I had installed SP1 yesterday, and it wasn't
crashing....it's got to be because of that though, since I've never had
a problem like that.
The registry thing sounds logical enough....maybe I'll try to uninstall
Studio today. I'll do the same as Gord and have a look for reg keys that
don't get removed on the uninstall....
Andrew
Dave Wilson wrote:
> Based on earlier threads from Bill D it may be related to registry
> entries and items from earlier versions.
> On the other machines did you have any previews installed or just the
> release stuff? I suspect that on the working machines you never had any
> Studio previews installed.
> Dave
> -----Original Message-----
> From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
> Sent: Friday, November 24, 2006 10:07 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] MapGuide Studio and DXF / DWG problems....
> Mapguide was first in my case and no I don't run them at the same time.
> I have uninstalled Map2007 and studio and then re-installed Studio with
> no change in results.
> When I run Studio I watch the status line and it goes through the entire
> load sequence and after loading managedmapapi it says opening test.dwg
> and immediately gives the dbx cas4 4 error.
> I can see the load sequence happening on a machine that works and it is
> the same sequence.
> From: Dave Wilson [mailto:dave.wilson at autodesk.com]
> Sent: Friday, November 24, 2006 10:01 AM
> Which product was installed first? I assume MapGuide was last?
> You aren't running both apps at the same time are you? You can only run
> 1 MapGuide instance when doing DWG imports because of the underlying
> Autocad engine that is loaded. That would imply you can't run Map or
> Civil at the same time either. If it's not a runtime problem then it has
> to be DLL's.
> Dave
> Sent: Friday, November 24, 2006 9:57 AM
> Andrew,
> Sorry I misread your post a little.  The 2d/3d issue is not with DXF it
> is with DWF.  I was having a problem with both but the DWF was just the
> 3d issue.
> I have AutoCAD Map 3d 2007 on my machine.  However, I have tried it
> successfully on other machines that have the same version of the
> software and it works fine.
> There is definitely something strange going on here because you are the
> third person I know who has this issue.  Not sure how Autodesk resolves
> it if they cannot reproduce the problem.
> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> Sent: Thursday, November 23, 2006 8:12 PM
> Subject: Re: [mapguide-users] MapGuide Studio and DXF / DWG problems....
> After posting here, I did think to go check the Autodesk groups and saw
> your post (with no solution). I don't see why they're be any 3D info in
> my dxf, but I'll give it another shot tomorrow and make sure it's 2D
> only.
> As for the version, this has happened with all versions available from
> the Autodesk website. Currently I'm using the latest one with SP1......I
> should also note that I've got AutoCAD Land Desktop and Civil 3D
> installed on my PC.....conflicting dll's sounds to me like a pretty
> logical problem.....the only question is how to fix it!
> Andrew
> Gord McKenzie wrote:
>> I have the same issue and error.  If you look on the Mapguide
>> newsgroups on the Autodesk news server, you will see I have posted to
>> separate messages about this problemThe first time Bill Dhimitri tried
>> to give some helpful suggestions but they did not work.  The second
>> time I asked, after applying SP1, I got no replies.  I have had this
>> problem on my notebook since day 1.  I have a client who purchased
>> Studio and they have the same problem.  I have tried installing the
>> Studio software on a couple of other machines in the office and it has
>> worked fine for DWG data.  The drawings are not the issue as I can use
>> the same DWG on one machine and it works but not on another.  There is
>> something amiss here but no luck so far from Autodesk.  .  General
>> Autodesk knowledge base alludes to this being an ARX/DLL conflict or
>> version error of some sort.
>> FYI, I found that if you have a 2d DWF you can work with it in Studio.
>> If it is a 3d DWF it will not work.
>> So far I cannot find anything to answer the problem.
>> *From:* Dave Wilson [mailto:dave.wilson at autodesk.com]
>> *Sent:* Thursday, November 23, 2006 2:18 PM
>> *To:* users at mapguide.osgeo.org
>> *Subject:* RE: [mapguide-users] MapGuide Studio and DXF / DWG
> problems....
>> MapGuide Studio will allow you to import DWG files and convert them
>> either to SDF or DWF. If you have a sample DWG and DXF that generates
>> this error could you attach it? Maybe change the extension on the
>> files to ensure they won't get filtered out by email. I'm not 100%
>> sure on the DXF files.
>> What version of Studio do you currently have?
>> Dave
>> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> *Sent:* Thursday, November 23, 2006 1:20 PM
>> *Subject:* [mapguide-users] MapGuide Studio and DXF / DWG problems....
>> Has anyone been able to import DXF or DWG files using MapGuide Studio
>> (any version)? No matter what version of Studio (this happened in all
>> of the demo versions) I use, and no matter what dxf or dwg file I try
>> to bring in, I always get a fatal error msgbox that pops up and says
>> "DBX CAS 4".....useful. You would think, being an Autodesk product,
>> that Studio would actually be able to bring in AutoCAD files in some
>> form, rather than just DWFs.....anyone else get this to work?
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
