[mapguide-users] MapGuide Studio and DXF / DWG problems....
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Nov 29 12:22:12 EST 2006
Mine's definitely from the Studio folder....If we knew which dlls it
needed and where they were meant to be found, maybe we could trouble
shoot this a little better....
Andrew
Traian Stanev wrote:
> Is it by any chance loading the wrong DLL, particularly the wrong
> acdb17.dll? If you have a tool like depends.exe you should run it and
> see where dete.exe is loading its dependencies from -- if it is not from
> the Studio directory then that would be the problem.
> Traian
> -----Original Message-----
> From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
> Sent: Friday, November 24, 2006 12:07 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] MapGuide Studio and DXF / DWG problems....
> Mapguide was first in my case and no I don't run them at the same time.
> I have uninstalled Map2007 and studio and then re-installed Studio with
> no change in results.
> When I run Studio I watch the status line and it goes through the entire
> load sequence and after loading managedmapapi it says opening test.dwg
> and immediately gives the dbx cas4 4 error.
> I can see the load sequence happening on a machine that works and it is
> the same sequence.
> From: Dave Wilson [mailto:dave.wilson at autodesk.com]
> Sent: Friday, November 24, 2006 10:01 AM
> Which product was installed first? I assume MapGuide was last?
> You aren't running both apps at the same time are you? You can only run
> 1 MapGuide instance when doing DWG imports because of the underlying
> Autocad engine that is loaded. That would imply you can't run Map or
> Civil at the same time either. If it's not a runtime problem then it has
> to be DLL's.
> Dave
> Sent: Friday, November 24, 2006 9:57 AM
> Andrew,
> Sorry I misread your post a little. The 2d/3d issue is not with DXF it
> is with DWF. I was having a problem with both but the DWF was just the
> 3d issue.
> I have AutoCAD Map 3d 2007 on my machine. However, I have tried it
> successfully on other machines that have the same version of the
> software and it works fine.
> There is definitely something strange going on here because you are the
> third person I know who has this issue. Not sure how Autodesk resolves
> it if they cannot reproduce the problem.
> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> Sent: Thursday, November 23, 2006 8:12 PM
> Subject: Re: [mapguide-users] MapGuide Studio and DXF / DWG problems....
> After posting here, I did think to go check the Autodesk groups and saw
> your post (with no solution). I don't see why they're be any 3D info in
> my dxf, but I'll give it another shot tomorrow and make sure it's 2D
> only.
> As for the version, this has happened with all versions available from
> the Autodesk website. Currently I'm using the latest one with SP1......I
> should also note that I've got AutoCAD Land Desktop and Civil 3D
> installed on my PC.....conflicting dll's sounds to me like a pretty
> logical problem.....the only question is how to fix it!
> Andrew
> Gord McKenzie wrote:
>> I have the same issue and error. If you look on the Mapguide
>> newsgroups on the Autodesk news server, you will see I have posted to
>> separate messages about this problemThe first time Bill Dhimitri tried
>> to give some helpful suggestions but they did not work. The second
>> time I asked, after applying SP1, I got no replies. I have had this
>> problem on my notebook since day 1. I have a client who purchased
>> Studio and they have the same problem. I have tried installing the
>> Studio software on a couple of other machines in the office and it has
>> worked fine for DWG data. The drawings are not the issue as I can use
>> the same DWG on one machine and it works but not on another. There is
>> something amiss here but no luck so far from Autodesk. . General
>> Autodesk knowledge base alludes to this being an ARX/DLL conflict or
>> version error of some sort.
>> FYI, I found that if you have a 2d DWF you can work with it in Studio.
>> If it is a 3d DWF it will not work.
>> So far I cannot find anything to answer the problem.
>> *From:* Dave Wilson [mailto:dave.wilson at autodesk.com]
>> *Sent:* Thursday, November 23, 2006 2:18 PM
>> *To:* users at mapguide.osgeo.org
>> *Subject:* RE: [mapguide-users] MapGuide Studio and DXF / DWG
> problems....
>> MapGuide Studio will allow you to import DWG files and convert them
>> either to SDF or DWF. If you have a sample DWG and DXF that generates
>> this error could you attach it? Maybe change the extension on the
>> files to ensure they won't get filtered out by email. I'm not 100%
>> sure on the DXF files.
>> What version of Studio do you currently have?
>> Dave
>> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> *Sent:* Thursday, November 23, 2006 1:20 PM
>> *Subject:* [mapguide-users] MapGuide Studio and DXF / DWG problems....
>> Has anyone been able to import DXF or DWG files using MapGuide Studio
>> (any version)? No matter what version of Studio (this happened in all
>> of the demo versions) I use, and no matter what dxf or dwg file I try
>> to bring in, I always get a fatal error msgbox that pops up and says
>> "DBX CAS 4".....useful. You would think, being an Autodesk product,
>> that Studio would actually be able to bring in AutoCAD files in some
>> form, rather than just DWFs.....anyone else get this to work?
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
