Operation is not valid due to the current state of the object
Joy Appler jappler at my.bcit.ca
Thu Nov 30 13:44:21 EST 2006
  I had the same error message apearing, however once I installed the patch I
had a new error message.  It reads: Method not found: 'Boolean
Autodesk.MapGuide.Studio.Fdo.FdoUtil.GetShpSchema(System.String,
System.String)'.     Does anyone have any ideas as to where I went wrong,
and why the patch didn't work.
Thanks,
Joy Appler
Bill Dhimitri wrote:
> Willem,
> This sounds like a known problem.  Here is what Ed posted about this
> earlier:
> It turns out that our shp->sdf conversion code was failing to insert a
> feature from the source shp file into the destination sdf file whenever
> the geometry property of the source feature is NULL.
> The relevant Studio code has been fixed, and a patched dll has been
> posted at
> https://mapguide.osgeo.org/files/documents/12/40/Autodesk.MapGuide.Studi
> o.Fdo.zip
> <https://mapguide.osgeo.org/files/documents/12/40/Autodesk.MapGuide.Stud
> io.Fdo.zip> . To apply this patched dll to your current Studio Preview
> installation, unzip this dll, overwriting the existing one (ex:
> C:\Program
> Files\Autodesk\MapGuideStudioPreview\Autodesk.MapGuide.Studio.Fdo.dll)
> Another way to fix this is to download and install the new Studio from
> www.autodesk.com/mapguidestudio
> Bill
>   _____
> From: Willem Schwarte [mailto:willem at giskit.nl]
> Sent: Thursday, April 06, 2006 9:18 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Operation is not valid due to the current
> state of the object
> When dragging SHP files to STUDIO and Clicking on Load Resources I get
> this error:
> I have tried different shapes.
> Which object are we talking about anyway? Studio , or the shapes?
> Willem
View this message in context: http://www.nabble.com/Operation-is-not-valid-due-to-the-current-state-of-the-object-tf1405831.html#a7625268
More information about the Mapguide-users mailing list
