mapguide install on FC4.
alba a.penitente at gepaspa.com
Tue Oct 3 12:24:18 EDT 2006
I must install mapguide os 1.0.1 on Fedora 4 with gcc 4.0.2
to install FDO 3.1 I have downloaded from
https://fdo.osgeo.org/downloads.html
fdo3.1.0_data_R050.tar
fdo3.1.0_R050.tar.gz
? OpenSourceBuild_README.txt
? export
LD_LIBRARY_PATH=/usr/local/fdo3.1.0/lib:/home/OpenSource_FDO/thirdparty/linux/cppunit/lib
? cd /home/OpenSource_FDO
? sh build_linux.sh
? make install
? OpenSourceTestData_README.txt
the instructions of the file OpenSourceTestData_README.txt are for FDO 3.0,
if I replace 3.0 with 3.1 the test it fails as I must set the variable
LD_LIBRARY_PATH?
I have set
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo3.1.0:/usr/local/
fdo3.1.0/
include/Shp:/usr/local/fdo3.1.0/
include/SDF
or
export
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/gis/fdo/3.1:/usr/local/gis/fdo/3.1/Shp
cd /home/OpenSource/Providers/SDF/Src/UnitTest
./UnitTest
cd /home/OpenSource/Providers/SHP/Src/UnitTest
./UnitTest
but it doesn't work.
I have download e installed FDO 3.2 according to the instructions of the
handbook ?Building FDO
Open Source? from page 35
cd /home/OpenSource
./setenviroment.sh
./build_thirdparty.sh
./build_linux.sh ?--d build
cd /home/OpenSource/Fdo/UnitTest
./UnitTest
./UnitTest
./UnitTest
null.
For Mapguide open source 1.0.1, can I use FDO 3.2?
thank, hello Alba
Nick Sadowy wrote:
> Can you send me the error that you are seeing?  I don't remember off hand
> what I did to get it to install.  If I see the error, I will know what
> steps I took for FDO.
> I'll give gcc 4.0.2 a try.  Thanks for the suggestion.
> Nicholas Sadowy
> Sr. Information Manager
> CD-Data, Inc.
> 2330 E. Bidwell St, Suite 200
> Folsom, CA 95630
> (916) 817-2211 x106
> nick at cd-data.com
> http://www.cd-data.com
> -----Original Message-----
> From: alba [mailto:a.penitente at gepaspa.com]
> Sent: Monday, October 02, 2006 11:52 PM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] mapguide install on FC4.
> Hi Nick
> also I had the same problems, but I have installed gcc 4.0.2 and not gcc
> 4.0.0 of FC4.
> now would want to ask I one what you?
> which are the steps that you have executed in order to install FDO 3.1
> and to make the date test?
> thank you
> Alba
> Nick Sadowy wrote:
>> Hi All.
>> I am having a heck of a time getting mapguide to compile all the way
>> through.  I have been able to overcome some hurdles by making the
>> individual packages that failed, but I haven't had any luck getting over
>> this latest issue:
>> During the make, I am getting the following error:
>> Making all in Service
>> make[2]: Entering directory
>> `/usr/local/src/mapguide-1.0.1/Common/Service'
>> /bin/sh ../../libtool --tag=CXX --mode=link g++  -O2 -g -pipe -march=i386
>> -mcpu=i686 -fno-use-cxa-atexit -fexceptions   -o libMgCommon.la -rpath
>> /usr/local/mapguideopensource/lib -version-info 7:0:0
>> -L../../Oem/dbxml-2.2.13/install/lib -L../../Common/CoordinateSystem
>> ServiceControllerBuild.lo ServiceCoordinateSystemBuild.lo
>> ServiceDataBuild.lo ServiceExceptionBuild.lo ServiceGeometryBuild.lo
>> ServiceMapLayerBuild.lo ServiceNetBuild.lo ServiceServicesBuild.lo
>> ServiceSystemBuild.lo ServiceUtilBuild.lo -lxerces-c -lMgCoordinateSystem
>> ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
>> ../Security/libMgSecurity.a
>> *** Warning: Linking the shared library libMgCommon.la against the
>> *** static library ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a is
>> not
>> portable!
>> *** static library ../Security/libMgSecurity.a is not portable!
>> g++ -shared -nostdlib
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.o
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/crtbeginS.o
>> .libs/ServiceControllerBuild.o .libs/ServiceCoordinateSystemBuild.o
>> .libs/ServiceDataBuild.o .libs/ServiceExceptionBuild.o
>> .libs/ServiceGeometryBuild.o .libs/ServiceMapLayerBuild.o
>> .libs/ServiceNetBuild.o .libs/ServiceServicesBuild.o
>> .libs/ServiceSystemBuild.o .libs/ServiceUtilBuild.o
>> -L/usr/local/src/mapguide-1.0.1/Oem/dbxml-2.2.13/install/lib -lxerces-c
>> -lMgCoordinateSystem ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
>> ../Security/libMgSecurity.a -L/usr/lib/gcc/i386-redhat-linux/4.0.0
>> -L/usr/lib/gcc/i386-redhat-linux/4.0.0/../../.. -lstdc++ -lm -lc -lgcc_s
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/crtendS.o
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crtn.o  -march=i386
>> -mcpu=i686 -Wl,-soname -Wl,libMgCommon.so.7 -o
>> .libs/libMgCommon.so.7.0.0/usr/bin/ld: cannot find -lMgCoordinateSystem
>> collect2: ld returned 1 exit status
>> make[2]: *** [libMgCommon.la] Error 1
>> make[2]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common/Service'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common'
>> make: *** [all-recursive] Error 1
>> [root at user2 mapguide-1.0.1]#
>> Is it normal to have all these problems getting mapguide Open Source up
>> and running?  I am on a clean build of Fedora Core 4.
>> Thank you in advance.
>> Nick
>> Nicholas Sadowy
>> CD-Data, Inc.
>> Folsom, CA 95630
>> (916) 817-2211 x106
>> nick at cd-data.com
> http://www.nabble.com/mapguide-install-on-FC4.-tf2372882.html#a6615146
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/mapguide-install-on-FC4.-tf2372882.html#a6623684
More information about the Mapguide-users mailing list
