[mapguide-users] SQL Server 2005
Lockyer James James.Lockyer at bradford.nhs.uk
Fri Oct 6 03:05:39 EDT 2006
Hi Keith
You may also find some limited info on the User manager in the Essential FDO document.  There is a copy of this on the OSGeo website under the FDO documentation.
Jim
From: Campbell, Keith A [mailto:keith.campbell at atkinsglobal.com]
Sent: Thu 05/10/2006 16:54
Subject: RE: [mapguide-users] SQL Server 2005
Warren,
Thanks for the Info. I've now found some limited detail on the FdoUserManager in Map Help, and also this; http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7180801&linkID=2786831. The process for SQL Server will be similar, I guess.
Keith
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: 05 October 2006 15:30
Hello Keith,
The basic process is as follows:
    - Create the datastore using the FdoUserManager.exe found in the <Map Install>\FDO\Bin folder
    - Create a user for this datastore using the same tool above.
As for getting data into the store...  this is the tricky part as there are no direct tools in Map to get dwg data into the datastore.  Once connected, you could define the schema manually and populate it manually in Map.  However one method I have employed for getting data into the datastore is to export the dwg data as SHP (yes I know there are inherent problems with this method...  i.e. Arcs), and then connecting to that SHP file, and then performing a Bulk Copy from the SHP to the SS Datastore.  This method has worked pretty well to populate the SS datastore.
Hope this helps.
   Warren Medernach
   IMAGINiT Professional Services
Sent: Thursday, October 05, 2006 3:22 AM
Robert,
>From what I can see, the documentation that comes with Map 2007 is somewhat lacking when it comes to detailing how data, including the geometry, can be put into SQL Server. E.g. do we need a blank database on the SQL instance? Can you point me to any documentation?
Keith
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: 04 October 2006 18:03
Jim,
The AGF is a legacy name valid until FDO 3.1 that is showing in the doc.  Although it still show up in the doc, it has been replaced by FGF (FDO Geometry Format) for API function and class names in FDO 3.2    e.g. GisAgfGeometryFactory became FdoFgfGeometryFactory
Look into the FDG_FDODevGuide.pdf under "The Geometry API". It describes the binary format.
There is an API to simplifies reading/wrting binary AGF.
There is also a text version AGF text (search AGF Text).
RF
From: Lockyer James [mailto:James.Lockyer at bradford.nhs.uk]
Sent: Wednesday, October 04, 2006 11:37 AM
Hi Robert
Thanks for that, I read some of the documents but none stated that the FDO SQL only worked if you had Map 3D - it was something I guessed by accident when I was trying to reverse engineer the process of connection.  So effective FDO to me would mean one that didn't rely on me purchasing a third software package.
What information is there about FGF binary format? I've managed to create an SQL file which sorts out the meta data on the SQL file.  I'd stopped when I established that the expected datasource was in fact binary rather than GML (which was my firt thought as to how data could be stored).
Jim
Sent: Wed 04/10/2006 15:59
Jim,
I guess as for the documentation, it is an oversight and should be fixed.  Some of this documentation exist from the FDO side (FDG_FDODevGuide.pdf and FET_TheEssentialFDO.pdf available on the open source side)   But I agree that even there there is not enough and could be further refine.
Mapguide SP1 will introduce performance enhancement for reading data.  I hope that it will cover some of your concern with your Odbc case.
"And is there any intention of creating an effective FDO for SQL."
I'm not sure what you would consider an effective provider for SQL server.  SQL Server doesn't have native support for geometry.  Therefore, we need some mechanism to deal with it.  Like I said, you can still read data out of SQL server but that has limited use if you can't get your geometry out of it.  The geometry is currently stored in FGF binary format and the database requires FDO metadata in order to work with geometry.
We look at supporting geometry stored in OGC WKT format to give some flexibility for non-FDO enable database but it is not currently implemented at this time.
RF
Sent: Wednesday, October 04, 2006 10:09 AM
Cheers,
Can I ask why it has taken three months to point that out or why this is not mentioned in the any of the help files/ published material on the internet or for that matter why the UK resellers are unaware of this fact.  And is there any intention of creating an effective FDO for SQL.
In case you have X,Y,Z coordinates stored in different columns, the ODBC provider should be used against SQL Server data. - has this been speeded up in the latest release?  As when I tried this it took over 40 minutes to map out four points.
Has anyone thought about using GML as a storage mechanism?
Jim
James Lockyer
GIS Specialist
IM&T
Bradford and Airedale Teaching PCT
New Mill, Victoria Road, Saltaire, Shipley, West Yorkshire, BD18 3LD
Tel: 01274 366031
This email is intended for the use of the addressee only and may contain confidential information, copyright material or views/opinions that do not necessarily reflect those of the organisation. If you receive this email by mistake please advise the sender immediately. All should be aware that this email may be subject to public disclosure under the Freedom of Information Act 2000 and that emails are monitored periodically.
Sent: Wed 04/10/2006 14:39
The SQL Server provider is intented to work with datastore created with Map 3D 2007 inside SQL Server 2000 and 2005.
It has it's own geometry storage and spatial indexing mechanism.  Although it could reverse engineer existing database, this would be done for non-spatial data only as it has no mean to identify geometry property in the database.
Just wanted to make sure the provider was not being used for what it was not design for.
RF
Sent: Wednesday, October 04, 2006 2:59 AM
Supported yes - does it work... now that's the question.
From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
Sent: Tue 03/10/2006 22:04
Thanks
Sent: Tuesday, October 03, 2006 1:33 PM
Hello Gord,
I was informed by the ADN that the FDO provider supports: SQL Server 2000 (SP4) and SQL Server 2005.
Warren Medernach
This message has been scanned for viruses by MailControl <http://bluepages.wsatkins.co.uk/?4318150>
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding. <http://www.blackspider.com/>
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061006/9dbfb60a/attachment.bin
More information about the Mapguide-users mailing list
