SQL Server Secondary Data Source
Campbell, Keith A
keith.campbell at atkinsglobal.com
Fri Oct 6 04:20:33 EDT 2006
Skipped content of type multipart/alternative-------------- next part --------------
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.GetDefaultableFeatureClass(List`1 classes)
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.ValidateFeatureSources(FeatureClass& primaryClass, String& resourceId, FeatureClass& joinClass)
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.CreateNewExtension(String resourceId)
at Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.JoinControlTree.toolBar_ButtonClick(Object sender, ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.OnButtonClick(ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.WmReflectCommand(Message& m)
at System.Windows.Forms.ToolBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Studio
Assembly Version: 1.0.0.17804
Win32 Version: 1.0.0.17804
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Studio.exe
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.MapGuide.Studio.Locale
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Locale.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINNT/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd/msvcm80.dll
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.UI.DLL
Autodesk.Gis.DwfToolkit
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.Gis.DwfToolkit.DLL
Autodesk.MapGuide.Studio.Feature
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Feature.DLL
Autodesk.MapGuide.Studio.FdoLoader
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.FdoLoader.DLL
Autodesk.MapGuide.Forms
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Forms.DLL
Autodesk.MapGuide.Studio.Site.UI
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Site.UI.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Site.DLL
Autodesk.MapGuide.Studio.MdfModel
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.MdfModel.DLL
Autodesk.MapGuide.Studio.ImageEngine
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.ImageEngine.DLL
Autodesk.MapGuide.Studio.Load
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Load.DLL
Autodesk.MapGuide.Studio.Load.Serializer
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Load.Serializer.DLL
Autodesk.MapGuide.Studio.Dwg.Load
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Dwg.Load.DLL
System.Web
CodeBase: file:///C:/WINNT/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Configuration
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.JScript
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
a3is0r7y
jhklyoxd
te2fmixj
qpkn0a88
bzdwwesi
ofup7obw
pojxgdek
jemknjvy
Autodesk.Gis.CoordinateSystems
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.Gis.CoordinateSystems.DLL
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Microsoft.mshtml.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Fdo.DLL
xq4kpq-c
System.Data
CodeBase: file:///C:/WINNT/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Autodesk.MapGuide.Studio.StylePreview
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.StylePreview.DLL
Accessibility
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
xw7hcyo-
upghpoj_
ICSharpCode.SharpZipLib
Assembly Version: 0.81.0.1407
Win32 Version: 0.81.0.1407
CodeBase: file:///C:/Program%20Files/Autodesk/MapGuideStudio2007/ICSharpCode.SharpZipLib.DLL
a0-emsl5
p3un3get
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
More information about the Mapguide-users
