[mapguide-users] Setting the Active Aelection with .Net
Andy Morsell
amorsell at spatialgis.com
Tue Oct 10 11:07:42 EDT 2006
In your JavaScript function, are you passing the .NET selectionXml somehow?
For example:
var selectionXml = '<%= selectionXml %>';
parent.parent.SetSelectionXML(selectionXml);
Also, can you confirm that you are getting to the SetSelectionXML() function
properly? If your code is running in the script frame, try this instead:
parent.mapFrame.SetSelectionXML(selectionXml);
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
Sent: Tuesday, October 10, 2006 6:55 AM
Subject: [mapguide-users] Setting the Active Aelection with .Net
Based on the example in the Developer' Guide on page 45-48 I create an
aspx-file with following code to select a parcel by a given key.
Unfortunately nothing is selected in the map. So what's wrong with my code?
I am exspecially not sure about how the xml-file with the selection is
passed to the map.
<% Response.Charset = "utf-8";
GetRequestParameters();
mapName = "New Map";
InitializeWebTier();
MgUserInformation cred = new MgUserInformation(sessionId);
MgSiteConnection site = new MgSiteConnection();
site.Open(cred);
MgFeatureService featureSrvc =
site.CreateService(MgServiceType.FeatureService) as MgFeatureService;
MgResourceService resourceSrvc =
site.CreateService(MgServiceType.ResourceService) as MgResourceService;
MgRenderingService renderingSrvc =
site.CreateService(MgServiceType.RenderingService) as MgRenderingService;
MgMap map = new MgMap();
map.Open(resourceSrvc, mapName);
MgLayerCollection layers = map.GetLayers();
string name = "ALK_Nutzungen";
MgLayer layer = layers.GetItem(name);
MgFeatureQueryOptions query = new MgFeatureQueryOptions();
query.SetFilter("Key LIKE '3966/000 at 3970'");
string featureClass = layer.GetFeatureClassName();
MgResourceIdentifier featureSource = new
MgResourceIdentifier(layer.GetFeatureSourceId());
MgFeatureReader features = featureSrvc.SelectFeatures(featureSource,
featureClass, query);
MgSelection sel = new MgSelection(map);
sel.AddFeatureIdInt32(layer, featureClass, 0);
Response.AddHeader("Content-type", "text/xml");
selectionXml = sel.ToXml();
Additional I have a Javascript function:
function OnPageLoad()
The xml-file looks like this:
<?xml version="1.0" encoding="UTF-8" ?>
- <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd">
- <Layer id="b9410078-ffff-ffff-8000-00142ab4c581">
- <Class id="SDF_2_Schema:ALK_Nutzungen">
<ID>AAAAAA==</ID>
</Class>
</Layer>
</FeatureSet>
Thanks in advance to all,
Melanie
View this message in context:
http://www.nabble.com/Setting-the-Active-Aelection-with-.Net-tf2416837.html#
a6736960
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
