[mapguide-users] RE: is inaccessible due to its protection level
Andy Morsell
amorsell at spatialgis.com
Tue Oct 10 13:49:11 EDT 2006
You have the line that declares realMapName commented out and then you are
trying to use it in the below statement.
Andy
-----Original Message-----
From: Cory Gregor [mailto:cgregor at barkerlemar.com]
Sent: Tuesday, October 10, 2006 10:15 AM
Subject: [mapguide-users] RE: is inaccessible due to its protection level
Thank You Andy that fixed that problem.
Can you help me with this problem? It is telling me that the Line
map.Open(ResouceService, realMapName); is telling me that " ResourceService"
does not exist in the current context.
There is most of my code....
String mapDefinition =
"Library://Samples/FredWeber/Maps/Default.MapDefinition";
String webLayout = "Library://Samples/FredWeber/FredWeber.WebLayout";
String sessionId = "";
String NoLayers = "No Layers Selected";
try
MapGuideApi.InitializeSockets();
string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
String configPath = realPath + "webconfig.ini";
MapGuideApi.MgInitializeWebTier(configPath);
MgUserInformation userInfo = new MgUserInformation("Administrator",
"admin");
MgSite site = new MgSite();
site.Open(userInfo);
sessionId = site.CreateSession();
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService ResourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
MgFeatureService FeatureService =
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
MgFeatureQueryOptions QueryOptions = new MgFeatureQueryOptions();
//string realMapName = Request.ServerVariables["mapName"];
MgMap map = new MgMap(mapDefinition);
MgSelection selection = new MgSelection(map);
selection.Open(ResouceService, "map");
MgLayer Layers = new MgLayerCollection(map);
if (Layers)
for (i = 0; i < Layers.GetCount(); i++)
//Only check selected features in the Parcels layer.
Layers = Layers.GetLayerType(i);
if (Layers && Layers.GetLayerDefinition() == "Default_Map
Base_727(3)")
//Create a filter containing the IDs of the selected
//features on this layer
LayerClassName = Layer.GetFeatureClassName();
selectionString = selection.GenerateFilter(Layer,
LayerClassName);
//Get the feature resource for the selected layer
LayerFeatureId = Layer.GetFeatureSourceId();
LayerFeatureResource = new
MgResourceIdentifier(LayerFeatureId);
//Apply the filter to the feature resource for the
// selected layer. This returns
//an MgFeatureReader of all the selected features.
QueryOptions.SetFilter(selectionString);
FeatureReader =
FeatureService.SelectFeatures(LayerFeatureResource, LayerClassName,
QueryOptions);
//Process each item in the MgFeatureReader, displaying
the
//owner name and address
while (FeatureReader.ReadNext())
val = FeatureReader.GetString("FeatureID");
//FeatureReader.GetString("Layer");
echo val;
else
echo NoLayers;
MapGuideApi.TerminateSockets();
catch (MgException mge)
Response.Write(mge.GetMessage());
Response.Write(mge.GetDetails());
If there is any think that is not correct please let me know.
Thanks,
Cory
Andy Morsell wrote:
> Try this instead (the email will probably wrap the lines);
> MgResourceService;
> MgFeatureService;
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> Sent: Tuesday, October 10, 2006 6:58 AM
> Subject: [mapguide-users] is inaccessible due to its protection level
> OK, first of all i am new at the whole MGOS and C#. I gotten maps to
> show
> up fine. So i am guessing that my server is configured correct. i am
> running IIS 6 on Win 2k3 server. I am using Visual Studio 2005.
> I keep getting this error and can not find any help if it.
> Compiler Error Message: CS0122:
> 'OSGeo.MapGuide.MgResourceService.MgResourceService()' is inaccessible due
> Source Error:
> Line 47: MgMap Map = new MgMap();
> Line 48:
> Line 49: MgResourceService ResouceService = new
> MgResourceService();
> Line 50: MgFeatureService FeatureService = new MgFeatureService();
> Line 51: MgFeatureQueryOptions QueryOptions = new
> Am i using the it Wrong?
> The goal is to get the Layer Name and the ID from the layer and pass it
> to
> another page.
> Please help if you can. I am pass a deadline of this.
> Thanks,
> Cory
http://www.nabble.com/is-inaccessible-due-to-its-protection-level-tf2416853.
> html#a6737010
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
html#a6741102
More information about the Mapguide-users
