[mapguide-users] Resource data was not found
Cory Gregor cgregor at barkerlemar.com
Wed Oct 11 15:16:11 EDT 2006
Thanks Robert,
That got me pass that error.  The map.Create worked.
On to the next bug.   :)
Thanks,
Cory
Robert Bray-2 wrote:
> This problem is not related to session timeout. MgMap.Open takes the
> name of the runtime map object, not a MapDefinition. Is this script
> invoked by an InvokeURL command? If so you should be getting the MAPNAME
> and SESSION parameters from the post data. The MAPNAME parameter should
> be passed into MgMap.Open as the second argument. The SESSION parameter
> should be used in the creation of MgUserInformation.
> If you are not running this script from InvokeURL, then you need to call
> MgMap.Create instead, passing in an instance of MgResourceService, the
> resource id of the Map Definition, and name of the runtime instance of
> the map to create. There is no way to hook up a map created in this way
> back to the viewer however (or at least no way that I am aware of).
> Bob
> François Van Der Biest wrote:
>> You might find a solution to your problem here :
>> http://www.nabble.com/How-to-check-if-session-is-expired--tf2218864.html#a6549987
>> It took me a lot of time to find this trick.
>> F.
>> Cory Gregor a écrit :
>>> The code is blowing up on this line:  map.Open(ResourceService,
>>> mgResourceID);
>>> The browser is telling me " Resource datawas not found:
>>> RuntimeDataResource
>>> data was not found: ....."
>>> Is the some IIS config problem maybe?  IIS 6 on Win2k3 Server.
>>> Here is the code...
>>>     //String mapDefinition =
>>> "Library://Samples/FredWeber/Maps/Default.MapDefinition";
>>>     //String webLayout =
>>> "Library://Samples/FredWeber/FredWeber.WebLayout";
>>>     String sessionId = "";
>>>     String NoLayers = "No Layers Selected";
>>>     try
>>>         MapGuideApi.InitializeSockets();
>>>         InitializeWebTier();
>>>         MgUserInformation userInfo = new
>>> MgUserInformation("XXXX","YYYY");
>>>         MgSite site = new MgSite();
>>>         site.Open(userInfo);
>>>         sessionId = site.CreateSession();
>>>         MgSiteConnection siteConnection = new MgSiteConnection();
>>>         siteConnection.Open(userInfo);
>>>         MgResourceService ResourceService =
>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>> MgResourceService;
>>>         MgFeatureService FeatureService =
>>> siteConnection.CreateService(MgServiceType.FeatureService) as
>>> MgFeatureService;
>>>         MgFeatureQueryOptions QueryOptions = new
>>> MgFeatureQueryOptions();
>>>         MgResourceIdentifier mgResourceID = new
>>> MgResourceIdentifier(mapDefinition);
>>>                 MgMap map = new MgMap();
>>>                 map.Open(ResourceService, mgResourceID);
>>>         Response.Write("Got here");
>>>         MgSelection selection = new MgSelection(map);
>>>         selection.Open(ResourceService, "map");
>>>         MgReadOnlyLayerCollection Layers = selection.GetLayers();
>>>         if (Layers.GetCount() > 0)
>>>             for (int i = 0; i < Layers.GetCount(); i++)
>>>                 //Only check selected features in the Parcels layer.
>>>                 MgLayer Layer = Layers.GetItem(i);
>>>                 if (Layer != null && Layer.GetLayerDefinition() == new
>>> MgResourceIdentifier("Default_Map Base_727(3)"))
>>>                     //Create a filter containing the IDs of the
>>> selected                     //features on this layer
>>>                     string LayerClassName = Layer.GetFeatureClassName();
>>>                     string selectionString =
>>> selection.GenerateFilter(Layer,
>>> LayerClassName);
>>>                     //Get the feature resource for the selected layer
>>>                     string LayerFeatureId = Layer.GetFeatureSourceId();
>>>                     MgResourceIdentifier LayerFeatureResource = new
>>> MgResourceIdentifier(LayerFeatureId);
>>>                     //Apply the filter to the feature resource for
>>> the                     // selected layer. This returns
>>>                     //an MgFeatureReader of all the selected features.
>>>                     QueryOptions.SetFilter(selectionString);
>>>                     MgFeatureReader FeatureReader =
>>> FeatureService.SelectFeatures(LayerFeatureResource, LayerClassName,
>>> QueryOptions);
>>>                     //Process each item in the MgFeatureReader,
>>> displaying
>>> the                     //owner name and address
>>>                     while (FeatureReader.ReadNext())
>>>                         string val =
>>> FeatureReader.GetString("FeatureID");
>>>                         //FeatureReader.GetString("Layer");
>>>                         Response.Write(val);
>>>         else
>>>             Response.Write(NoLayers);
>>>         MapGuideApi.TerminateSockets();
>>>     catch (MgException mge)
>>>         Response.Write(mge.GetMessage());
>>>         Response.Write(mge.GetDetails());
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Resource-data-was-not-found-tf2419141.html#a6762775
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide-users mailing list
