[mapguide-users] ArcSDE
triplederby100-propos at yahoo.com
Tue Oct 17 12:05:35 EDT 2006
You will find these three DLL (sde91, sg91 and pe91) on an ArcGIS installation, even if you don't have ArcSDE installed. These are also used by the ArcGIS desktop (to connect to SDE databases). Important thing to make sure is that you have SDE license (enterprise geodatabase) to use them. If you have a *running* intallation of ArcSE, probabaly you have the ArcSDE license. In that case, yes, you can use those libraries progammatically. Also, nature of the license too plays a role here - if you have acquired ArcSDE under EDN, you can only use for development purposes (no production). I am not sure if these can be physically copied to another machine to work with the ArcSDE FDO provider though.
Kaarigar
----- Original Message ----
To: "users at mapguide.osgeo.org" <users at mapguide.osgeo.org>
Sent: Tuesday, October 17, 2006 8:51:32 AM
Subject: RE: [mapguide-users] ArcSDE
thanks Robert
I know you probably cannot answer this definitively since its an ESRI
question but if you have ArcSDE installed on your server, you should be able
to use the client libraries on the same server (or any server that connects
to that ArcSDE instance), right?
cheers
brian
-----Original Message-----
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Tuesday, October 17, 2006 11:10 AM
The ArcSDE client libs are not redistributable. They need to come with
proper licensing from ESRI products.
RF
From: Brian Flood [mailto:BFLOOD at SPATIALDATALOGIC.COM]
Sent: Tuesday, October 17, 2006 10:17 AM
To: 'users at mapguide.osgeo.org'
thanks Orest, that was the page I was looking for.
are the sde client libraries distributable?
cheers
brian
From: Orest Halustchak [mailto:orest.halustchak at autodesk.com]
Sent: Tuesday, October 17, 2006 8:32 AM
Hi Brian,
Yes, the source code for the ArcSDE provider is available as open source
(https://fdoarcsde.osgeo.org/).
It uses SDE client libraries. You have to make sure that you have these
dll's available and in your path: sde91.dll, sg91.dll, and pe91.dll. It
does not currently support raster, but it does support versioned
databases through the FDO long transaction versioning commands.
Thanks,
Orest.
Sent: Monday, October 16, 2006 3:26 PM
Subject: [mapguide-users] ArcSDE
hello all
a few questions on the ArcSDE SDO for Oracle/SQLServer
1) Is the source code available as part of the free community download?
If
no, any pointers on where to find out about Enterprise?
2) Does it use native SQL communication or does it rely on the SDEClient
libraries provided by ESRI?
3) How's the performance when compared to other SDE access layers? How
about
ESRI tools?
4) Does it have Raster support?
5) Long shot - does it work with Versioned geodatabases? (e.g. delta
tables)
cheers
brian
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061017/b1e2e53e/attachment.html
More information about the Mapguide-users
