[mapguide-users] bad performance with mysql or sql server
Bruce Dechant
bruce.dechant at autodesk.com
Mon Oct 23 11:48:17 EDT 2006
The connections are not closed because the MapGuide server is caching them for performance. As a temporary workaround you can do the following, but this will cause a performance impact because the MySQL connections will no longer be cached.
Edit the serverconfig.ini file and add the MySQL provider to the list of excluded providers. (See below)
DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP,OSGeo.MySQL
Bruce
_____
From: ARQUICAD-MATIAS [mailto:massigoge at arquicad.com]
Sent: October 20, 2006 11:47 AM
Subject: [mapguide-users] bad performance with mysql or sql server
I'm having problems with MySQL FDO Provider. The MapGuide OS 1.0.2 never close connections to MySQL so the it reach the maximun connection number and the FDO stop working.
The DataConnectionTimeout in serverconfig.ini is set to 600 seconds but it doesn't work.
Thanks.
Matías Massigoge
Ingeniero de Aplicación
Departamento Infraestructura
Arquicad SRL
Tel (011)4811-1733/15-6204-7686
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061023/c24932cd/attachment.html
More information about the Mapguide-users
