[mapguide-users] Build MG open source 1.0.2 using FDO 3.1.0 R050
Bruce Dechant bruce.dechant at autodesk.com
Mon Oct 23 17:53:24 EDT 2006
This is not recommended at all. MG open source build 1.0.2 was built
with FDO R071 and is designed for that version. There are several
defects in FDO R050 that have been fixed in FDO R071 that you will not
benefit from. Also, the MG server has had code changes made to work with
the fixes/changes in FDO R071 that do not exist in FDO R050.
Bruce
-----Original Message-----
Sent: October 23, 2006 2:22 PM
Subject: [mapguide-users] Build MG open source 1.0.2 using FDO 3.1.0
R050
Hi. I cannot build FDO R071, so i decided to use the R050 version to
build MG open source 1.0.2, beacuse i cannot build FDO R071 on Fedora
Core 5.
Is there a problem with this solution ???
Hope you can help on this.
Ernesto
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
