[mapguide-users] MapGuide 1.0.2 with Autodesk Raster FDO?
Federico Primon
federico.primon at abitat.it
Tue Oct 24 10:14:43 EDT 2006
Thanks a lot Frank,
I'll manage to compile all the stuff from SVN...
Keep up the good work!
Best Regards
Federico
Federico Primon
Data and Content Management
ABITAT Sistemi Informativi Territoriali
Via Roma, 5 - 36026 Pojana Maggiore (VI)
Tel. 0444 794127 - Fax 0444 898220 - Mobile 348 3668085
federico.primon at abitat.it - www.abitat.it
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, October 24, 2006 4:05 PM
Subject: Re: [mapguide-users] MapGuide 1.0.2 with Autodesk Raster FDO?
Federico Primon wrote:
> Hi all,
> I've just downloaded release 1.0.2 for Windows, along with the FDO
> Providers samples: is there an explanation about the distribution of
> Autodesk Raster Provider (3.1 R071)?
> Does it means that Autodesk will release the code to the community?
> Where can I find the code to compile GDAL Provider 3.1 R071?
Federico,
The FDO GDAL provider is available in the SVN repository of the project
at http://fdogdal.osgeo.org/
However, the provider was implemented against the development FDO API
which is FDO 3.2. That means it is, unfortunately, not possible to use
it with FDO 3.1 applications, such as the public release of MapGuide.
I have successfully tested it with the development version of MapGuide
for those brave enough to do everything directly from SVN.
I believe Autodesk is providing use of the Autodesk Raster Provider
as a stopgap till the release MapGuide is using FDO 3.2, but it not
expecting to release the source to it. It depends on quite a variety
of internal components I believe.
I hope this helps explain the situation a bit, even if it doesn't
accomplish anything for you in the short term.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
