[mapguide-users] King.Oracle 0.3.3
Butler, Juan P jpbutler at co.pinellas.fl.us
Tue Oct 24 21:10:28 EDT 2006
Haris:
Are you still getting the error?   I'm at home now and I'm able to pull it up.   Please let me know...Maybe it's one of those oddities about Enterprise.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is subject to the Public Records Law of Florida.
Sent: Tue 10/24/2006 6:28 PM
Subject: RE: [mapguide-users] King.Oracle 0.3.3
I am getting this after login as Anonymous:
An unclassified exception occurred. Exception occurred in method MgWebLayout.ParseWebLayoutDefinition at line 294 in file c:\build_tux_area\mgdev\web\src\webapp\WebLayout.cpp
Haris
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, October 24, 2006 11:19 PM
Haris:
I'm seeing some other strange things.  The labels on some of my polygons have odd characters in them.  Not sure where these are coming from.
http://gis.co.pinellas.fl.us/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fPinellas%2fLayouts%2fkingtest.WebLayout&LOCALE=en
Use Anonymous for the user and zoom into a scale of at least 10,000 to pull up the parcels.  Then hover over one of them.   The performance for these coming up is great.
I'm just stumped on why the Evacuation Routes are not displaying with the parcels.  Same coordinate system in the database.  The layer previews fine too.  I can see them when editing the layer style; just can't see them when I place the layer in the map.
GIS Applications
Sent: Tuesday, October 24, 2006 4:43 PM
Hi Juan,
I am looking at this memory usage.
Which version of MG are you using ?
Haris
Sent: Tuesday, October 24, 2006 10:26 PM
True...I was thinking about it.  I would just need to construct the GEOMETRY in the view.   I'll try it out.
Thanks.
GIS Applications
Sent: Tuesday, October 24, 2006 3:31 PM
I would suspect it is a memory leak in provider. I will check it.
"I just wish I could use this for non Oracle Spatial tables with coordinate fields" - you mean like displaying points from x,y columns ?
Beside suporting it in provider, one of the ways could be to create a view in Oracle for it.
Haris
Sent: Tuesday, October 24, 2006 7:52 PM
Haris:
I'm testing this now and it seems that your provider is pulling up the spatial data much faster.  The only problem that I'm running into is the server process is eating up memory at a large clip when adding more layers from Oracle.  It's gotten up to over a GIG.   I've had to shutdown Mapguide server completely and then restart it.  The memory usage will go back up as I interact with more Oracle spatial layers.  Not sure if it's more on the Mapguide server side or the provider.
I just wish I could use this for non Oracle Spatial tables with coordinate fields.  The ODBC provider will not show tables for me.
GIS Applications
Sent: Tuesday, October 24, 2006 7:17 AM
Subject: [mapguide-users] King.Oracle 0.3.3
newer version of King.Oracle 0.3.3 provider:
*	Support for Spatial Views
	It will display views based on spatial tables. Views needs to be added into sdo_geom_metadata for provider to find them.
Get it here: www.sl-king.com/fdooracle
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061024/c74f7958/attachment.html
More information about the Mapguide-users mailing list
