[mapguide-users] King.Oracle 0.3.3
Haris Kurtagic haris at sl-king.com
Wed Oct 25 09:13:54 EDT 2006
Hi Joel,
Regarding selecting, I tested it again and I am able to select layers
wich comes from tables with primary keys.
Right now primary key is only way to tell provider to use that column as
identity.
Any sugestions are welcome.
I should do something for views also.
Note:
 It seems there is an issue in viewer regarding selecting:
If you have a large scale layer and then zoom in much smaller and then
you click on feature, mg will send wrong coordinates for selecting on
that click
hence tooltip will work, it send different coordinates to provider for
tooltip and click on.
If you take that same layer and put in the map, and give map a smaller
extents, click on and tooltip works.
Haris
-----Original Message-----
Sent: Tuesday, October 24, 2006 8:05 PM
Subject: Re: [mapguide-users] King.Oracle 0.3.3
Fantastic! Talk about agile development. My views showed up and are now
displaying. I'm having some performance problems, but those could easily
be my fault. Too much data on too small a machine. Still, I have a gig
of ram on my machine, and while I was browsing a map, I completely
filled it up. I don't think that should happen?
Weirdest thing I have found is that none of my map features in DWF or
AJAX are selectable, even though I set them up to be in map definition
haris kurtagic wrote:
> Hi,
> newer version of King.Oracle 0.3.3 provider:
> *	Support for Spatial Views
> 	It will display views based on spatial tables. Views needs to be
> added into sdo_geom_metadata for provider to find them.
> Get it here: www.sl-king.com/fdooracle
> Haris
View this message in context:
http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6978386
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
