Oracle Spatial Advanced and FDO driver compatibility
Francisco Javier Rojas Duran francisco.rojas at dasoft.com.mx
Wed Oct 25 12:14:17 EDT 2006
Hi:
Using Adsk FDO Provider for Oracle Spatial I have no problems with
information previously written by Adsk Map 2005 OSE which is the same since
Map 2004 trough 2006.
The Spatial Metadata is automatically generated when the Features were
written into Oracle.
If you want to migrate oracle spatial info from AMAP 2004 to AMAP 2007 for
read/write then you must setup the schema with the new FDO Manager.
Regards.
Francisco Javier Rojas Durán
IT Manager - Oracle Specialist
Grupo DaSoft S.A. de C.V.
-----Mensaje original-----
De: Amit Stein [mailto:amitstein at gmail.com]
Enviado el: Martes, 24 de Octubre de 2006 01:28 p.m.
Para: users at mapguide.osgeo.org
Asunto: Oracle Spatial Advanced and FDO driver compatibility
I have an Oracle schema with spatial tables, created through the
"Oracle Spatial Advanced" feature from Autodesk Map 2004.
It is possible to read this tables from MapGuide Open Source, with the
"King Oracle provider for MapGuide Open Source", or with any other
driver?
(It is necessary to create some fdo metadata tables?)
If is is not possible, how can I convert my data to be able to read it
from MapGuide Open Source?
thanks
More information about the Mapguide-users mailing list
