[mapguide-users] RE: King.Oracle 0.3.3
Haris Kurtagic haris at sl-king.com
Wed Oct 25 13:51:39 EDT 2006
Hi Joel,
Thank you for your comments.
Regarding geometry type, basically you can do it when defining spatial
index type in Oracle. This could also improve performance especially on
points
Also key columns can be defined via primary key ( unique wouldn't be ok
because I think fdo wouldn't recognise null as a key )
Yes, In principle I don't like of putting a lot of metadata inside db,
but when is necessary
Haris
-----Original Message-----
Sent: Wednesday, October 25, 2006 7:42 PM
Subject: [mapguide-users] RE: King.Oracle 0.3.3
Its seems to me that eventually you will have to rely on user supplied
metadata to solve this problem. For each table or view, a user would be
able to specify a key column and also maybe what type of geometry
(point,line, poly, mixed, etc...) is in the table. Specifying a type of
geometry would be nice, so that layers created from feature classes are
correctly displayed in legend. Eventually, you will probably need to
allow for other types of metadata as well. This info could be stored in
a table within Oracle or in a config file internal to the provider. I'm
not sure that it matters.
Joel
haris kurtagic wrote:
> Hi Joel,
> Regarding selecting, I tested it again and I am able to select layers
> wich comes from tables with primary keys.
> Right now primary key is only way to tell provider to use that column
> as identity.
> Any sugestions are welcome.
> I should do something for views also.
> Note:
>  It seems there is an issue in viewer regarding selecting:
> If you have a large scale layer and then zoom in much smaller and then
> you click on feature, mg will send wrong coordinates for selecting on
> that click hence tooltip will work, it send different coordinates to
> provider for tooltip and click on.
> If you take that same layer and put in the map, and give map a smaller
> extents, click on and tooltip works.
> Haris
> From: Joel Carranza [mailto:jec at gatekeeper.com]
> Sent: Tuesday, October 24, 2006 8:05 PM
> Subject: Re: [mapguide-users] King.Oracle 0.3.3
> Fantastic! Talk about agile development. My views showed up and are
> now displaying. I'm having some performance problems, but those could
> easily be my fault. Too much data on too small a machine. Still, I
> have a gig of ram on my machine, and while I was browsing a map, I
> completely filled it up. I don't think that should happen?
> Weirdest thing I have found is that none of my map features in DWF or
> AJAX are selectable, even though I set them up to be in map definition
>> Hi,
>> newer version of King.Oracle 0.3.3 provider:
>> *	Support for Spatial Views
>> 	It will display views based on spatial tables. Views needs to be
>> added into sdo_geom_metadata for provider to find them.
>> Get it here: www.sl-king.com/fdooracle
>> Haris
> http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6978386
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6996820
More information about the Mapguide-users mailing list
