[mapguide-users] SQL Server Provider vs. FDO Provider for a feature join...
Campbell, Keith A keith.campbell at atkinsglobal.com
Mon Oct 30 09:01:29 EST 2006
Hi Warren,
I'm not sure that this is going to be much help other than to confirm
that you should be able to do what you want. I can't see anything you're
doing wrong based on your description.
Firstly, yes, the ODBC option is the way to go to create your join.
I have got this arrangement working, though I have not had the problem
you mention regarding assignment of the coordinate system. I've saved an
arbitrary coordsys in my data connection and everything works.
Are you using version 1.0.2? It has a number of enhancements in this
area.
I've also found that if the SQL database is not local to the MapGuide
Service, this significantly impacts the performance, making
configuration of the join / layer frustrating to say the least.
Keith
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: 27 October 2006 16:50
Subject: RE: [mapguide-users] SQL Server Provider vs. FDO Provider for a
feature join...
Correction...
Subject should read:  SQL Server FDO Provider vs. ODBC Provider...
Warren
Sent: Friday, October 27, 2006 9:01 AM
Subject: [mapguide-users] SQL Server Provider vs. FDO Provider for a
feature join...
Hello all,
I want to create a join from and SDF feature source, to a SQL Server
database.
I read in the list that the SQL Server FDO Provider is only for
accessing datastores within SQL Server (datastores created with Autodesk
Map).
So, that would leave the ODBC Provider to connect to SQL Server for the
join.  However, I cannot get this to work...  I can choose the ODBC
Provider, and specify the DSN to my SQL Server, Test Connection is
successful, but when I try to set the coordinate system, this is never
'saved'.  This causes a problem, as it seems to give an error anytime
you try to join a feature source that doesn't have a coordinate system
assigned.
Btw, I was successful in getting this to function with an Access
dbase...
Any help and/or guidance would be greatly appreciated.
Warren Medernach
This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061030/0d0e8b1b/attachment.html
More information about the Mapguide-users mailing list
