Filters Not Working
Campbell, Keith A keith.campbell at atkinsglobal.com
Mon Oct 30 11:39:01 EST 2006
While trying to get date-based themes to work, I've come across another
problem (a bug maybe) with Filters. If I enter a condition for a theme
such as Field < AnotherField this works as expected. If the same
condition is put into a Filter on the same layer, no data is displayed.
I'm assuming this means an error has occurred, but no error message is
returned.
The Studio Help suggests that the expression dialog box for the Filter
and Theming is the same, and it makes sense that it would be. So I would
expect a condition to work equally well in both.
Another oddity I've come across is when using the 'Get' button in the
expression dialog box. This should return a list of unique values for
the selected field. However, I get an error message titled 'Unable to
complete request to site' and the message 'Parameter was not found:
Fieldname' when accessing data (via a feature join) in a SQL Server
table. The condition itself does work when used in a theme. However, if
I use the 'Get' button with fields in a different SQL Server table, but
in the same database, I do not get this error message. I can see no
reason for this.
All these types of issue make it a slow and painful process trying to
set up a working application.
Sure would be nice if somebody (especially somebody from Autodesk) could
shine some light on these things...
Keith
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061030/b97ed819/attachment.html
More information about the Mapguide-users mailing list
