[mapguide-users] Building Search based on joined fields
Andy Morsell amorsell at spatialgis.com
Mon Oct 30 15:30:55 EST 2006
I noted the same error under the same circumstances with 1.0.1 and
Enterprise.  I was hoping it was fixed in 1.0.2 (which I have not had time
to work with yet), but it looks like the bug lingers. (you are using 1.0.2
aren't you?)
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: Monday, October 30, 2006 12:20 PM
Subject: [mapguide-users] Building Search based on joined fields
Is it possible to create a search based on a value in a joined field?
I'm getting the following error when I attempt search a joined field:
An exception occurred in FDO component. Invalid identifier name '<Field
Name>'. Exception occurred in method
MgServerGwsGetFeatures.GetMgClassDefinition at line 207 in file
c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures.cpp
Anybody successfully getting search results from a joined field?
Thanks
Warren Medernach
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061030/23001727/attachment.html
More information about the Mapguide-users mailing list
