[mapguide-users] Raster features are not shown
Mindaugas Bliūdžius mindaugas at infoera.lt
Sat Sep 2 09:32:52 EDT 2006
Hi Bruce,
Thank you for answer! Maybe you know when SP1 will be ready to release? And
when the next (I think 1.0.2) version of MapGuide Open Source is planned for
release?
Mindaugas
  _____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Friday, September 01, 2006 10:39 PM
Subject: RE: [mapguide-users] Raster features are not shown
Mindaugus,
This is a know issue that has been fixed for the latest SVN “Branch”. If you
build the OS from the “1.0.x” branch you will have this fix.
This will also be included with the MapGuide Enterprise SP1 release.
Bruce
  _____
From: Mindaugas Bliudžius [mailto:mindaugas at infoera.lt]
Sent: August 31, 2006 1:12 AM
Subject: [mapguide-users] Raster features are not shown
I‘m having similar problem to this topic „rasters, always rasters!“. When i
try to see raster in Studio or elsewhere i get this in error.log:
Error: An exception occurred in FDO component.
        Failed to de-serialize the spatial contexts from the configuration.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandler.cp
p
  - MgOpDescribeSchemaAsXml.Execute line 110 file
c:\build_tux_area\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cp
p
  - MgServerDescribeSchema.DescribeSchema line 493 file
c:\build_tux_area\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 189 file
  - MgFdoConnectionManager.Open line 221 file
c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp
I launched http://localhost/mapguide/mapagent/index.html and tried
DescribeSchema method of Feature Service API. And i get the same error. I
called method leaving „Schema“ textbox empty, maybe there must be entered
something? . Any ideas?
I‘m using Windows Server 2003 Enterprice Edition Service Pack 1 (not R2).
Installed web extension using IIS and .NET as programming language (and
later used typical installation option). I‘m having the same problem with
MapGuide Enterprise 2007 and with MapGuide Open Source 1.0.1.
Mindaugas Bliūdžius
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060902/c0de8d26/attachment.html
More information about the Mapguide-users mailing list
