[mapguide-users] RE: WMS and EPSG:4326
Chris Claydon
chris.claydon at autodesk.com
Thu Sep 7 11:59:23 EDT 2006
I'm looking into this problem at the moment. Here's what I've found so
far:
The coordinate system conversions are failing because the web tier fails
to read the environment variable PROJ_LIB, which provides the location
of the coordinate system data files. (On my machine: C:\Program
Files\MapGuideOpenSource\Server\nad). This prevents the Proj4 libraries
from loading the data that allows them to convert EPSG codes into WKT.
On Apache this can be fixed by setting the environment variable in
httpd.conf. This can be achieved by adding:
SetEnv PROJ_LIB "C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\nad"
to the end of this file.
I am in the process of figuring out the equivalent fix for IIS. Once we
have that, the installers will be updated to add the required settings
automatically.
To solve another mystery...
The OgcWmsService.config.awd file that Andy has posted contains a
mapping from EPSG:4326 to a WKT string. In the XML, this mapping is
commented out, but there is a bug in the parser that means that it gets
read anyway. When this config file is used, the mapped WKT string is
used directly, and no attempt is made to determine a mapping using
Proj4. That's why it works.
Chris.
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: September 7, 2006 9:11 AM
Subject: RE: [mapguide-users] RE: WMS and EPSG:4326
The attachment is in the archives at:
https://mapguide.osgeo.org/servlets/ReadMsg?list=users&msgNo=2721 but
depending on your browser, may not download well. I have zipped it and
placed it on my server. You can download it from here:
http://www.spatialgis.com/OgcWmsService.config.zip
Andy
From: David Hamilton [mailto:d.n.hamilton at jiffle.net]
Sent: Thursday, September 07, 2006 4:22 AM
Subject: [mapguide-users] RE: WMS and EPSG:4326
The attachment was stripped from the copy on your message posted to this
forum, which will prevent any newbie (such as me) who is researching
this
issue from solving it!
Is it possible that someone could either host the file and post the URL,
or
mail me a copy directly, and I'll host the file myself (copyright issues
permitting, of course).
Thanks
/david
Andy Morsell wrote:
> That's a strange problem, isn't it? Attached is the
> OgcWmsService.config.awd file that Antonio de la Pena sent me (thanks
> again Antonio). I think he tried to send it to the group once, but it
> didn't work. So, let me know if you don't get it and I can send you a
> private message instead.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> _____
> From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
> Sent: Thursday, August 24, 2006 9:49 AM
> Subject: [mapguide-users] WMS and EPSG:4326
> I have read the extensive thread, between Andy and Thomas, on the
> subject of WMS and EPSG:4326. I am having the exact same problem and
> am unable to sort it out. There was a copy of an awd file mentioned
> but it did not seem to be attached to any of the posts. Is this file
> the answer to the problem and if so is it available somewhere?
> Thanks
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context:
http://www.nabble.com/WMS-and-EPSG%3A4326-tf2159810.html#a6188570
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users
