[mapguide-users] login: The specified user was not found
Andy Morsell amorsell at spatialgis.com
Fri Sep 8 17:07:03 EDT 2006
Hi Tom,
Sorry, no, I can't remember exactly what happened in those instances.  I've
installed and setup MapGuide at least 30 times now on various systems and
this was something I ran into more than once.  Once I got around it, I kept
moving.  I'll be sure to document it in the future.
Andy
  _____
From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Sent: Friday, September 08, 2006 1:43 PM
Subject: RE: [mapguide-users] login: The specified user was not found
Hi Andy,
If you are able to recall what steps you went through when it failed, we can
track it down. And if an artifact is entered for this that will make sure
that its progress can be tracked.
Hi Axel,
A couple of us here went through the steps that you provided and could not
reproduce the error.  Thanks for the detailed step. I did notice that the
error came up if I had used the wrong case for the user name since the
authentication is case sensitive. If you can still reproduce the problem,
could you enter an artifact in project tracker with the steps to reproduce?
Thanks
Tom
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, September 08, 2006 11:12 AM
Have you restarted the MapGuide service?  I've seen some odd things happen
when adding a new user through Admin and the change not "sticking" or having
to enter the information again.
Andy
  _____
Sent: Friday, September 08, 2006 10:02 AM
Subject: [mapguide-users] login: The specified user was not found
Freitag, 08.09.2006
Hello List,
i have created a weblayout and can display it. Before i can see anything i
have to login.
Using default user Administrator and password admin everything works fine.
Using a user i created within the
MG Site Administrator it doesn't work. I get the following error:
The specified user was not found: Username Exception occurred in method
MgSecurityCache.GetUserInfo at line 149 in file
c:\build_tux_area\mgdev_opensource\server\src\common\manager\SecurityCache.c
pp
I use MGOS 1.0.1, MS Windows Server 2000, IIS and PHP (should be 5.0.5 from
the installation).
What I did in MG Site Administrator:
I created a first new group an a first new user. I put the new user in the
new group. The new user is
a member of the built in group Everyone an my own group.
Like the an anonymous user the new user has no role like administrator or
map author.
When i want to edit my new user there is nothing in the field Password. I
expected to see at least the dots
representing the password i entered and confirmed the first time.
What I did in MG Studio, version 1.0.0.16802:
In the Site Explorer i edited the properties of the library i want to work
with. In "permissions"
i added my own user group and set the permissions to read/write. The
usergroup everyone
is still there.
Thanks for help!
Axel
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060908/f351be1c/attachment.html
More information about the Mapguide-users mailing list
