[mapguide-users] An exception occurred in FDO component.The Oracle runtime wasnot found (module
Kim Woynowskie kimw at ci.grandjct.co.us
Tue Sep 12 17:29:46 EDT 2006
10.2 oracle client
I also tested for the SQL server and it works/connects with no problem
To:<users at mapguide.osgeo.org>
Date: Tuesday, September 12, 2006
Subject: RE: [mapguide-users] An exception occurred in FDO component.The Oracle runtime wasnot found (module
Which Oracle provider are using Autodesk or King, and which version of Oracle client ?
Haris
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Tuesday, September 12, 2006 8:22 PM
The client is installed, I did double check to make sure.  (actually reinstalled the client) I also looked in the directory structure and found the oci.dll file.
Subject: RE: [mapguide-users] An exception occurred in FDO component. The Oracle runtime wasnot found (module OCI.dll)
Sound like you don't have Oracle client installed.
It will find tables which have record in xxx_sdo_geom_metadata view in Oracle.
Haris
Sent: Tuesday, September 12, 2006 6:26 PM
Subject: [mapguide-users] An exception occurred in FDO component. The Oracle runtime wasnot found (module OCI.dll)
I keep getting this error of being unable to connect to Oracle when I try to establish a connection with Studio.
When I work from the server, it does find the Oracle tables.
This is my first attempt at setting up a connection, any help will be appreciated.
Thanks
Kim
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060912/e95c5627/attachment.html
More information about the Mapguide-users mailing list
