[mapguide-users] An exception occurred in FDOcomponent.The Oracle runtime wasnot found (module
Dave Wilson dave.wilson at autodesk.com
Tue Sep 12 17:51:09 EDT 2006
I assume you must be working on a Windows server if the SQLServer
connection is working.
Modify your system Path variable to include the oracle directory where
the dll is located and it should work.
Dave
  _____
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Tuesday, September 12, 2006 3:30 PM
Subject: RE: [mapguide-users] An exception occurred in FDOcomponent.The
10.2 oracle client
I also tested for the SQL server and it works/connects with no problem
To:	 <users at mapguide.osgeo.org>
Date: 	Tuesday, September 12, 2006
Which Oracle provider are using Autodesk or King, and which version of
Oracle client ?
Haris
  _____
Sent: Tuesday, September 12, 2006 8:22 PM
Subject: RE: [mapguide-users] An exception occurred in FDO component.The
The client is installed, I did double check to make sure.  (actually
reinstalled the client) I also looked in the directory structure and
found the oci.dll file.
component. The Oracle runtime wasnot found (module OCI.dll)
Sound like you don't have Oracle client installed.
It will find tables which have record in xxx_sdo_geom_metadata view in
Oracle.
Haris
  _____
Sent: Tuesday, September 12, 2006 6:26 PM
Subject: [mapguide-users] An exception occurred in FDO component. The
I keep getting this error of being unable to connect to Oracle when I
try to establish a connection with Studio.
When I work from the server, it does find the Oracle tables.
This is my first attempt at setting up a connection, any help will be
appreciated.
Thanks
Kim
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060912/1f99e9a4/attachment.html
More information about the Mapguide-users mailing list
