RE: [mapguide-users] Cannot connect to MapGuide Server on local machine if no ne
robert fritz
robert-fritz at web.de
Wed Sep 13 07:03:40 EDT 2006
I 've got the same problem using another web-based software and my solution is:
Disable Media Sense in the Windows Registry:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters
Wert: DisableDHCPMediaSense
Typ: REG_DWORD
Value for "DisableDHCPMediaSense" should be 1.
regards,
Robert
I've recently discovered a really nagging problem with the MapGuide Server
being unreachable (both studio and viewer fail to connect to site server) if
no network connection is available. Even when I am connecting to the server
process from the same machine that it is running on! But the moment I plug
in a network cable, everything's fine again!
Is there any way to resolve this problem?
Regards,
Jackie Ng
_______________________________________________________________________
Viren-Scan für Ihren PC! Jetzt für jeden. Sofort, online und kostenlos.
Gleich testen! http://www.pc-sicherheit.web.de/freescan/?mc=022222
More information about the Mapguide-users
