[mapguide-users] WMS now in Google Earth
Andy Morsell
amorsell at spatialgis.com
Fri Sep 15 11:27:45 EDT 2006
So the WMS Server you are entering is your own or are you using
<http://data.mapguide.com/mapguide/mapagent/mapagent.fcgi>
http://data.mapguide.com/mapguide/mapagent/mapagent.fcgi? What did you try
in IE?
Andy
_____
From: Chris Tallman [mailto:ctallman at innomap.com]
Sent: Friday, September 15, 2006 8:20 AM
Subject: RE: [mapguide-users] WMS now in Google Earth
Ok I've gotten that far. For some reason or another, after I select the
layer I want, hit ok. It trys said selected layer. This is when its asking
for a password. I've even tried it in IE and I get challenged. I'm still
in version 1.0.0 if that helps.
Any Ideas?
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, September 15, 2006 11:15 AM
The .fcgi URL is the WMS Server URL and you don't open it directly in a
browser. You add that as a new WMS Server in the "Web Mapping Service
Parameters" Google Earth dialog box. Once you do that, it will show you the
layers that are on that WMS Server (MGOS) that are exposed via WMS.
Andy
_____
Sent: Friday, September 15, 2006 4:46 AM
Andy,
I'm being prompted for a password. Do you know what I'm missing? I've
tried different passwords and nothing seems to work.
Chris
_____
Sent: Thursday, September 14, 2006 1:10 PM
Subject: [mapguide-users] WMS now in Google Earth
For those of you who follow Google Earth happenings, the latest release of
beta 4 supports WMS as image overlay sources. It's very cool, pretty easy
to use and even includes a number of pre-reloaded WMS URL's. Our own DM
Solutions server is even listed (it's the last one in the list - easy to
find). If you have a previous version of GE, you have to uninstall it prior
to installing this version. This blog entry has some details on how to use
this feature: <http://www.ogleearth.com/2006/09/wms_how_does_it.html>
I tried it with some WMS layers from MapGuide Open Source and Enterprise and
it worked reasonably well. You may have to manually tweak the WMS request
parameters manually. For instance, change FORMAT=image/gif to
FORMAT=image/png or transparency doesn't seem to work. One thing to watch
out for, MapGuide only supports single layer WMS requests so do not try to
add more than one layer to the single overlay definition or it will fail.
Attached is a KMZ placemark of the Sheboygan hydrography layer from
Autodesk's demo server. If you want to work with the other layers there
just add a new WMS Server in the GE dialog using
http://data.mapguide.com/mapguide/mapagent/mapagent.fcgi <<...>>
Andy Morsell, P.E.
Spatial Integrators, Inc.
<http://www.SpatialGIS.com> http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060915/1add9c52/attachment.html
More information about the Mapguide-users
